trans issue
Old Sep 21, 2010 | 03:40 PM
elite1msmith's Avatar
elite1msmith
Default trans issue
need a little help
01 dodge ram 2500 4x4 5.9 v8 gas, "z"
Auto trans
110k miles
trans was rebuilt 96k
did a motor swap, drove it around maybe 50 miles or so, not too many issues, the shifts were a little funny. It makes a whine in gear or neutral
now the other day it started to kill the motor when i come to a stop.
I roll to the stop in nuetral and its fine, but hes the wierd thing, if i start the truck, drive it around with out going out of 1,2 its fine...once the shift to 3rd happens, and i come to a stop the motor wants to kill. If i shift back to nuetral or to manuel 1/2 everything goes back to normal, and then the situation resets itself.... i can go back into drive fine.... once it shifts up into 3rd, then same issue, its like coming to a stop with out using the clutch.
i was thinking the convertor at first, but why would the gear i choose have an effect? i would think rev, drive, 1 , 2 would all have the same effect? why can i switch into 1st, then go back to drive while sitting still and the situation resets itself with no issue?
Old Sep 21, 2010 | 03:49 PM
Sounds like the torque converter clutch is sticking... or the solenoid is... might want to post in MonteC's trans thread, and see what he suggests.
Old Sep 28, 2010 | 03:16 PM
elite1msmith
bump for some help, posted in monte C section, but no luck yet
Old Sep 28, 2010 | 09:24 PM
monsterram95's Avatar
monsterram95
I agree with HeyYou, definitely sounds like a clutch issue...but as there are multiple clutches in the auto trans, I can not really tell which clutch is the problem without opening up the transmission...if I had to guess I would say the rear clutch
