front right axle seal leaking after replacement
Old Sep 28, 2010 | 04:38 PM
  #31
zman17's Avatar
zman17
Retired Moderator - RIP
This might help (has pics) http://www.pavementsucks.com/tech-article-3.html
Old Sep 29, 2010 | 12:33 AM
  #32
matty675's Avatar
matty675
thanks for all the help fellas, ill let u guys know how it goes when im done
Old Sep 29, 2010 | 11:48 PM
  #33
matty675's Avatar
matty675
should i get the quad 4x4 kit with nok seals or chicago rawhide seals? is one better than the other?
Old Dec 31, 2010 | 03:12 PM
  #34
killacoon1's Avatar
killacoon1
when removing the carrier mine just fell right out real loose.. is that a bad thing i have heard everyone saying it was hard to get out didnt know if that was bad that mine just fell out.. i replaced my seals about 3 months ago and they are already leaking again.. so didnt know if that was my problem
Old Dec 31, 2010 | 04:00 PM
  #35
dhvaughan's Avatar
dhvaughan
i don't think it matters that the carrier is hard to get out or not. as long as the caps are torqued properly and its not roaring or flopping or too tight.
what brand of seals did you use? i've had poor luck with crappy timkens.
did you get them seated in properly without damage?
did you lube the seals and slide the axles in GENTLY?
Old Dec 31, 2010 | 04:29 PM
  #36
aim4squirrels's Avatar
aim4squirrels
Originally Posted by dhvaughan
the only thing french we know of in ga is salad dressing or the upstairs maid in a good **** flick. oh wait, lets not go there. squirrels will come in with some of his weird texas ****. LOL
well, i guess i've really screwed up this thread.... sorry.
I'll. Take that in French too! I've had a Redhook before, definitely not a bad beer. I'll take a Shiner Bock over most anything though.
Old Jan 4, 2011 | 12:38 AM
  #37
killacoon1's Avatar
killacoon1
yea i used the timkins but im sure they were in straight and i did lube them up
Old Jan 4, 2011 | 07:00 AM
  #38
dhvaughan's Avatar
dhvaughan
timken seals suck.
Old Jan 4, 2011 | 11:13 AM
  #39
Arachnyd's Avatar
Arachnyd
Originally Posted by zman17
After the intermediate shaft is removed, the bearing should almost come out by using your finger. If not, just bend an old screwdriver and pull it out from one side to another in rotation.
Sorry, I should read previous posts better! What Sheriff said. I thought he was talking about the shaft itself.
I banged on that bearing with a hammer and a metal rod from the other side and couldnt get it to budge... so I ended up repacking it inside the axle housing.
Old Jan 4, 2011 | 11:16 AM
  #40
Arachnyd's Avatar
Arachnyd
Also wanted to share (to make you feel better atleast) that it took 5 seal replacements in the course of a month before we got it seated properly and not- leaking.
