Tail light problem
1997, my left tail light is not working, but the signal, 4 way, and brake are. Right side all work fine.
I checked for voltage and none of the 3 wires at the socket have power when the headlight switch if fully extended. As I said, the right side works fine.
What/Where do I look for next?
Normally, if one works and the other does not, either the socket,bulb or the plug where the wires split off is the problem. There are two elements in the bulb as I'm sure you are aware of. Just because the brake light,hazards or directionals work. Doesn't mean the P lights will. They use a different element in the bulb.
You have to follow the harness along the frame. https://dodgeforum.com/forum/2nd-gen...n-rams.htmlGet a Haynes or download this . Either one will help a lot.
