misfire help plz!!!!!!
Old Sep 29, 2010 | 08:28 AM
csobania82's Avatar
csobania82
Angry misfire help plz!!!!!!
got a 98 dodge ram 5.9 with engine light keeps comin on. code says #5 misfire. po305 seems to run good for the most part, feels a little under powered but runs smooth. sometime it pulses lightly when i first let off the brake but nothin major, doesnt really hesitate. i replaced the plug didnt help, i replaced the wire,nope. finally i replaced the #5 injector and still no change . not better or worse. any suggestions. really annoying havin that light on. i erased the code several times after each fix and still comes on. ???????? plz help thanks!!!!!!!!!!! also i made sure the wires arent crossed....hmmmmm
Old Sep 29, 2010 | 10:02 AM
atlrus's Avatar
atlrus
unplug the pre-cat O2 sensor and see if it makes any difference. 95% of the misfires are due to bad O2 sensor...
Old Sep 29, 2010 | 10:18 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Check your wire routing. #5 and #7 can cause misfires if not routed properly.
Old Sep 29, 2010 | 11:08 AM
dodgeboy1979's Avatar
dodgeboy1979
I just had the same problem with my 2002, your distributor cap and rotor could be the culprits. It would be worth doing an inspection of these. With my #5 misfire i changed the plugs, wires cap and rotor and it solved the problem
Old Sep 29, 2010 | 07:19 PM
97ramnj's Avatar
97ramnj
buddys 98 had the same problem took the cap and rotor off, completely shot replaced them and the pre cat o2 sensor was bad so i replaced that, check engine light went right off and it ran perfect
Old Sep 29, 2010 | 08:12 PM
dhvaughan's Avatar
dhvaughan
misfire on a single cylinder won't have anything to do with O2.
check/replace cap and rotor, maybe replace wire #5, or at least swap it with another cylinder.
next step is to check compression to check for major malfunction.
Old Sep 29, 2010 | 08:30 PM
97ramnj's Avatar
97ramnj
its more then likely the cap and rotor, bet when you take yours off and look inside itll be filthy
Old Sep 30, 2010 | 09:09 AM
atlrus's Avatar
atlrus
You may also want to check the el. plug to the injector on #5. Once I had a misfire and it turned out that the plug was missing the little retaining clip and would come just a bit loose, but enough for a misfire.
Old Sep 30, 2010 | 09:48 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
This one time, at band camp...
Old Sep 30, 2010 | 11:48 AM
dodgeboy1979
LOL VW i don't wana know where you put your sparkplug lol
