Let's see those headliners!
Old Oct 5, 2010 | 02:51 AM
  #21
J McWillis's Avatar
J McWillis
Originally Posted by FarmBoy428
Are ya'lls dashes cracking from heat, or putting stuff on it?
Because I don't seem to have that problem.
There isn't one crack in my dash, and I am pretty sure it has the same one when it came off the assembly line.
Idk, I must be having good luck with my dash, but I may go with the black ABS plastic one of these days. And replace the old one.
I think they're all pretty notorious for cracking so you got lucky, just another area chrysler skimped on when it came down to it. Mine was cracked when I bought it. I just credit it to the TX sun and PO's not taking the time to keep it taken care of.
Originally Posted by J415
I hope I' not thread jackin', but how did you guys do the visors? those look difficult.
Well, I did them two different ways. Took one and split it open then covered it. Easier to cut, but ended up coming out less than perfect. After that we realized it'd be much easier to just slice the old fabric off and cover it, leaving a bit hanging off and stuffing the edges in to the seam of the visor. Came out much better, but I'm no pro. Overall I'm happy with it, but if you want it perfect it might take a pro's touch.
Originally Posted by VWandDodge
To add to that, how are the visors adjusted? My driver's side visor flops (swinging outward) and I'd like to tighten it. I've pulled it to get an idea, but nothing.
Mine weren't loose at all, so I can't really help there. My best guess would be looking somewhere around the mount, around the spring. Might be a bolt in there that tightens down the bar. Sorry I can't help.
Originally Posted by 99dodge318
to the op where did you get the real tree camo material? and how much was it per foot? how many feet did you get?
I picked it up at JoAnn's fabrics, they have a pretty good selection if you have one locally. Might have to do some running around to local fabric stores. $12.99 a yard, I went ahead and bought 3 yards and it was enough to do the headliner, both visors, and still have a good amount left over. Whatever you end up getting, make sure it's the 60 inch wide fabric. And get some good glue. I highly recommend the 3M Super 90.
Old Oct 5, 2010 | 08:23 AM
  #22
lord0fsal3m's Avatar
lord0fsal3m
I need to do mine soon as well.
What adhesives did you use?
because my material was so thick i just opted for a hot glue gun, couple burns later, all done. lol.
Originally Posted by J McWillis
And lord0fsal3m, that interior you got is pretty nice. Kinda diggin that diamond plating.
thanks, yea i was messing with diamond plate for another project and decided to make some stuff up for the truck, i really like the way it all come out.
i cut off the old stuff, tossed the old mirror, cut out a pattern a little bigger than the visor, sewed up 3 sides, slipped it on and fold one side in the other of the opening and hot glued it shut. its fuzzy so you can even see a seam. the mirrors are clip ons from pep boys, took the brackets off and glued them on.
Originally Posted by CBR900RR19
Sweet looking job!!! But WHAT no fuzzy dice????????
thanks. and as for the dice, i kinda like my visability. lol.
Old Oct 5, 2010 | 12:33 PM
  #23
RamSport97's Avatar
RamSport97
Originally Posted by Salex007
RamSport97 where did you get those seat covers?
There from Iggee Custom Seats. You can get them from their ebay store, or through them directly.
Old Oct 30, 2010 | 07:36 PM
  #24
redneckrocket38's Avatar
redneckrocket38
Did you guys pull off the old headliner material? What about the foam backing? Really thinking about doing this(I did my reg cab ford a few years ago and it turned out good).
Old Oct 30, 2010 | 10:46 PM
  #25
J McWillis's Avatar
J McWillis
I took it down to the board. The cloth will just yank off, then hit the foam with a good sized wire brush til your arm feels like it's gonna fall off, then light sanding will do the trick. At least that's how I went about it. Also used a light spray of windex to clean it up.
Old Oct 30, 2010 | 10:54 PM
  #26
mr freeze's Avatar
mr freeze
When I did mine I took off the fabric and scraped and rubbed off the old foam.It not hard,just time consuming.
Old Oct 31, 2010 | 09:30 AM
  #27
MaxPower1971's Avatar
MaxPower1971
Originally Posted by lord0fsal3m
PLUSH!!!!!!!!!
THAT is SOOOOOOOOOOO cool!!!!!
I love it
Old Nov 13, 2010 | 08:28 PM
  #28
redneckrocket38
I finally got my headliner done. I used the same ap black camo as some others on here and it turned out awesome. I also did the door panel fabric and mad some other custom little panels.
Old Nov 13, 2010 | 10:07 PM
  #29
working4ev's Avatar
working4ev
Man o man this is nice good job. Is that a custom center consoled I see there? I would like to get the dimensions on it if you have them.
Old Nov 14, 2010 | 08:32 AM
  #30
MilesBFree's Avatar
MilesBFree
Nice work by everyone above! ^^^
