Death Wobble..HELP!
Old Oct 29, 2012 | 06:47 AM
  #101
iRyaanzz's Avatar
iRyaanzz
Drag link drop bracket needs replaced. Stop spending money.
Old Oct 29, 2012 | 10:30 AM
  #102
So this part is free?
Old Oct 30, 2012 | 12:56 PM
  #103
iRyaanzz's Avatar
iRyaanzz
Nope I have a 5 inch suspension lift, so it came with the track bar drop bracket. But i had to replace mine because it was Cracked and didn't have all bolts. So you need to check the bracket that the end of the track bar in conected too. Try to shake the track bar to look for and loosen in it if it tight and sturdy then check to see if all bolts are in bracket
Old Oct 30, 2012 | 01:22 PM
  #104
UnregisteredUser's Avatar
UnregisteredUser
And in your mind that's the one and only true cause of all death wobble in all solid front axle four wheel drive vehicles on Earth?
Old Nov 2, 2012 | 01:01 AM
  #105
NCC74656's Avatar
NCC74656
i have found the most issues with control arms that are slightly off in length and bushings that are not tight enough in the arms. outside of that the drop brackets seem to be the most common cause in my experience. my friend picked up a skyjacker kit and got that wobble, we bought some expensive but dense bushings for all the parts and that solved it for him. the factory skyjacker bushings just had way to much play in them.
