1996 ram 1500 running rough
Old Oct 4, 2010 | 02:16 PM
sam_priem's Avatar
sam_priem
Default 1996 ram 1500 running rough
im having some trouble with my 96 ram, its making this wierd clanking sound when it idles. i thought maybe it was the exhaust system ratling from vibrations but then it started doing it when i accelerate. i started it up this morning and it sounded almost like it was coming from the transmission area. whenever i accelerate past 3000 rpm the check engine light flashes too. also when i turn on the overdrive, the whole truck jiggles from 50-60 mph. if anybody has had these problems or knows what i can do to fix them, i would appreciate the help.
Engine:
stock 1996 5.9L V8 magnum
stock 1996 transmission w/ overdrive
Old Oct 4, 2010 | 02:27 PM
sam_priem's Avatar
sam_priem
Default miles
i forgot to mention that it just rolled over 227,000 miles this morning if that helps at all
Old Oct 4, 2010 | 03:41 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Go bang on the Cat, I bet it rattles. And do a search here for "plenum"
Old Oct 4, 2010 | 03:48 PM
Andrew2500's Avatar
Andrew2500
Def sounds like a cat problem. Had the same thing with my old '94 ram.
