Key Test...Flash Code?
Old Jun 2, 2005 | 04:43 AM
HuntinHanson's Avatar
HuntinHanson
Default Key Test...Flash Code?
Hey ive read alot about people doing key test to get a flash code. Can anyone explain this to me as how to do it and things i should know about it? Thanks
Old Jun 2, 2005 | 01:34 PM
Redneck2345's Avatar
Redneck2345
Default RE: Key Test...Flash Code?
Turn your key on-off-on-off-on and watch your check engine light. Count the number of flashes, there will be a two second pause inbetween new numbers
Old Jun 2, 2005 | 01:57 PM
steve05ram360's Avatar
steve05ram360
and I think the 55 code means it's done... correct me if I'm wrong (it's been a while since I've had to do it)
Old Jun 2, 2005 | 03:57 PM
DCRam's Avatar
DCRam
Yes, code 55 flashes when the test is complete. Also, if you have ever disconnected your neg. battery cable the light will flash code 12 ( that's 1 flash..pause..2 flashes).
Old Jun 2, 2005 | 04:19 PM
Tani1500's Avatar
Tani1500
go here
http://dodgeram.org/tech/gas/Trouble/pcm_fault_code.htm
