1999 Dodge 3/4 Ton 4X4 starts and runs, but sometimes cranks over and then no spark
Old Oct 7, 2010 | 09:23 AM
merge's Avatar
merge
Default 1999 Dodge 3/4 Ton 4X4 starts and runs, but sometimes cranks over and then no spark
Hello all,
I have a 1999 Dodge 3/4 Ton 4X4 crew cab that I did some trading for and have a weird prolblem I been trying to chase down. The truck starts fine and runs with no issues, but once in a while when I go to restart it after its been running it will just crank over and not start. The engine spins very fast and sounds like it has no spark at all when this happens. Usually I can let the truck sit a while and it will then start again. I have noticed that this never happens when I start the truck for the first time, only after it has ran for a while and then try to restart. The other day it did this and it took an hour until the truck would restart. Yesterday, it only took a minute and it restarted. I am very confused as to what the problem is here. I was told by a mechanic that he thought it had something to do with the factory security system. Another mechanic said it sounded like the ignition switch had a short. Anyone had a similar issue or any advice what to check before I start throwing money at this thing? Is there a way to disable the factory security system?
Thanks in advance!
Old Oct 7, 2010 | 09:32 AM
Need to find out what's missing when it won't start. Fuel? Spark? Could be as simple as a failing sensor......
Old Oct 7, 2010 | 09:57 AM
zman17's Avatar
zman17
Retired Moderator - RIP
See if there are any codes stored.
Old Oct 7, 2010 | 10:39 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Security system sounds like BS.
I would check ALL the ignition stuffs.
Cap, rotor, coil, wires....etc.
Could also be, like HeyYou said, a sensor going out...
Old Oct 7, 2010 | 04:09 PM
crawlin95's Avatar
crawlin95
def not security system our trucks dont have a smart key and as long as you dont lock it with the key fob or you unlock it with it then the security system is going to be disabled. check for spark and fuel your problem sounds suspiciously like a fuel pump.
