clunking noise from rear when slowing
Old Oct 10, 2010 | 09:48 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Did you check the ujoints while in the air or on the ground?
Old Oct 13, 2010 | 12:17 AM
asgoodasded's Avatar
asgoodasded
checked the ujoints on the ground.
havnt been able to get the cover off yet to check it out, my gutters fell off and have been tryign to get that in order, lol.
Old Oct 13, 2010 | 07:53 AM
zman17's Avatar
zman17
You should raise the rear of the vehicle to check the ujoints..
Old Oct 13, 2010 | 10:56 AM
MilesBFree's Avatar
MilesBFree
+1 on u-joints.
Haven't done it on one of these trucks, but on other vehicles it is cheap (like $10 - 15 per set, one set needed at each the front and rear of the driveshaft (2 total)).
It is also a simple DIY job (at least on other vehicles I have worked on). So simple and cheap it would be worth it simply as a troubleshooting step, and if that is not it, well, you have new u-joints for a few bucks and an hour's time (or less).
Is it that simple on these trucks too?
Old Oct 13, 2010 | 11:09 AM
Yep. U-joints are dead easy. The only really complicated one is the CV joint on the t-case side of the front driveshaft. (two joints, a ball and spring, etc.)
Old Oct 13, 2010 | 11:14 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Drop the driveshaft and pull the u-joints. My truck was doing this for quite some time, and when I pulled the driveshaft I found a u-joint with a broken cap. The needle bearings had washed out who-knows-when, so every time I would accelerate or de-accelerate, the shaft would wobble, or flop, on that slight axis, making a clunk sound.
Old Oct 15, 2010 | 09:04 AM
dodgeman71's Avatar
dodgeman71
almost sounds like a differential gear tooth mesh problem. like when a tooth is chipped or missing
