3 Cables to TB on 95 with 318
Old Oct 10, 2010 | 03:17 PM
jpoole's Avatar
jpoole
Default 3 Cables to TB on 95 with 318
OK, I just changed my TB to a Fastman 50mm. It has 3 cable connections going to the throttle linkage. I know the one from the cruise and the gas petal. What is the 3rd one for?
Also, how the hell do you get that one coming from the cruise back on? I have tried twice but both times I take for a drive and notice it is back off. Also, does anyone know if this would cause the cruise light to stop coming one? I get why my cruise won't engage, but could the cable being off cause the indicator light to stop coming on?
thanks
Old Oct 10, 2010 | 03:31 PM
zman17's Avatar
zman17
Retired Moderator - RIP
One is for the gas "petal", one is the cruise, and the other is the TV cable. If you didn't pull the TV cable towards the front of the truck to disconnect it, you broke it, and that's why it won't stay on.
Old Oct 10, 2010 | 03:43 PM
Sniperinhisname's Avatar
Sniperinhisname
my tv cable connection thing broke at the Throttle body. where could i get a new connection. cause everytime i get on my truck it pops off at about 3/4 throttle
Old Oct 10, 2010 | 03:45 PM
jpoole's Avatar
jpoole
OK, TV cables, THANKS. I forgot about those. Yea, the TV cable has been broken for a while. It is the one on the outside of my linkage. It stays on but has a lot of slack on it. How do you adjust these things. I remember it was a big deal on my old 83 Hurst \ Olds.
I have noticed my truck shifts like a luxuary autombile...
The cruise cable is the one I can't get to stay on. It mounts to the inside of the linkage and is forward pull back also. It is not broken. It seems to be on but I am not feeling a slight click.
Old Oct 10, 2010 | 03:48 PM
zman17's Avatar
zman17
All three have the same type connection. They need to be pulled off forward or backward(a manual or the directions the FASTMAN came with will tell you that), not to the side. If you break it, a new cable is the only way to fix it.
Old Oct 10, 2010 | 04:25 PM
jpoole's Avatar
jpoole
Cruise now working. I guess 3rd time is a charm. Opened the throttle a bit and was able to slide cable on and felt the click. However, cruise light is not on. Probably bulb.
Old Oct 10, 2010 | 04:50 PM
zman17's Avatar
zman17
Scroll down in this thread for the factory TV cable adjustment https://dodgeforum.com/forum/2nd-gen...-in-trans.html
Old Oct 10, 2010 | 05:15 PM
jpoole's Avatar
jpoole
I checked mine while put the Cruise Cable on and it seems fine. Less than a mm play. Anyway, it is broken and I can't seem to find a replacement. Does anyone know where to pick one up or a part number?
I am Tivoing the Cowboys game and at 3 minutes left in the 1st we are loosing.... 10 - 0. But we are DRIVING!!!!
Old Oct 11, 2010 | 07:41 AM
Diefenbaker's Avatar
Diefenbaker
Replacement part number for the TV-cable is 5207 9204
check yourself at page 462: http://www.berrysprinter.com/e-Fiche.../81-96/94t.pdf
Old Oct 11, 2010 | 08:57 AM
redneck_ram's Avatar
redneck_ram
PM sent!
