Need help with a coolant leak
Hi,
I have a 97 Ram 1500 with a 5.9 V8. It is leaking antifreeze right behind the alternator. It is about .25 to .75 inch of a hole. It is just below and left of the thermostate housing. It is on the passenger side of the engine. It leaks if it is running or not running. Any help would be appreciated, no Dodge dealer in my area can help me, they all seem to have no knowledge of the 5.9 V8.
Thank you,
Brian
Thank you,
Brian
Brian,
I might be able to help you with this.
Can you take a picture or elaborate a little further, I might have a different setup in the 5.2L engine 2001 model year but I just got done replacing my water pump.
There is a hose that goes to the top of your water pump, if you can check that with a flashlight and see if there is leakage coming out of there, but the would be closer to in between the alternator and AC Compresser/Unit.
Please take a photo of the engine bay just behind the fan shroud, and the area you believe the leak is coming from..
Is it dripping down over top of your harmonic balancer pulley? Has it been over heated at all? When did you notice this?? About how much coolant is leaking out?
Looks to me where there should be your temp sensor Should be a single wire with a gray connector. The temp sender would go in that hole. Never seen one come out like that. That is the only hole right there. Just replaced mine. Your temp gauge should not even be working assuming you can run the engine.
Hi,
Thank you,
Brian
Thank you,
Brian
It would seem to me that you have a cylinder head problem. We have had the thermostat housing leak but only when the truck was running and hot.
sprntpshr
Trending Topics
That is just rust on the block. I was shinning a flashlight on the hole in addition to the flash on the camera. There was nothing being blown out of the hole, there is some gunk around the thermostate housing. It is not the temp sensor as there is one next to the heater core hose and the temp gauge is working. I am going to have it towed to my mechanic but he can't get to it till next Wensday.
Brian
Brian
Brian
Brian
Intake leak
Seeing as i've replaced lots of intakes in my day, there are coolant passages that run across the intake in the front and rear to each head an if its coming out of the corner of the intake/Head then your intake gasket is leaking on what looks like the left side. Its pretty common on higher mileage small blocks the gasket will deteriorate where the coolant flows, hopefully its not getting into the oil gallery.
