I learned something today!
Old Oct 13, 2010 | 06:43 PM
Justin3's Avatar
Justin3
Default I learned something today!
Today I learned that I am a dumb ***! No seriously, I recently made a thread about my rear brakes on my 2000 Ram locking up. I went with new Drums, new pads, wheel cylinders and a Hardware kit. It needed all 4 so this isn't one of those "money wasted" screw ups, however come to find out I put the shoes on backwards!! The Napa Pads didn't come with the studs installed for the brake adjuster, so I had to install them myself but ended up screwing up the placement. The Thinner Pads are for the front and the thicker pads are for the Rear... This makes sense since my truck stopped beautifully in reverse...
I ended up having to buy new pads since the thicker pads were worn down and I just didn't trust them. Thats ok, im just glad I solved my problem. If this never happened I wouldn't have known you could put the shoes on backwards, in school they just showed us remove and installing techniques..
Hoping someone else can use this info
Old Oct 13, 2010 | 07:10 PM
Mowhawk's Avatar
Mowhawk
The more you know
Old Oct 13, 2010 | 08:10 PM
charlie1935's Avatar
charlie1935
Show me someone that makes no mistakes and I'll show you someone that does nothing!
Old Oct 14, 2010 | 12:31 AM
CPTAFW163's Avatar
CPTAFW163
hey, at least you didn't set your truck on fire!! A few of us on here have.
Old Oct 14, 2010 | 12:34 AM
redheadhunter21's Avatar
redheadhunter21
Yeah and your not the first to do that or the last one, problem is nobody tells you theres a difference and some manuels will tell you that there is 2 different shoes but not tell you which is which
Old Oct 14, 2010 | 12:35 AM
matty675's Avatar
matty675
dont think they should be different thiknesses. however the front (primary shoe) has the shorter lining.
Old Oct 14, 2010 | 12:49 AM
J415's Avatar
J415
It happens to ALL OF USE. However, not all of us will admit it.
Old Oct 14, 2010 | 09:44 AM
bigslick050's Avatar
bigslick050
^^ +1
Had a problem with putting on my hardware correctly on one drum and it took me like 8 hrs to finish one side of my brakes!
Old Oct 14, 2010 | 12:32 PM
dhvaughan's Avatar
dhvaughan
or lies. LOL. glad you got it fixed.
Old Oct 14, 2010 | 12:47 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
The problem was a lack of beer.
