Alrighty Then Tranny Issues
Old Oct 15, 2010 | 06:13 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Rock Auto for one, look in "transmission auto" under "solenoid", Dodge dealer, local trans shop etc...
Old Oct 15, 2010 | 06:28 PM
New 96's Avatar
New 96
Originally Posted by seabass202
those frayed "wires" look more like a frayed wire loom to me.
They are black to the eye and around the colored Jacket wires
Old Oct 15, 2010 | 06:52 PM
zman17's Avatar
zman17
Yes, it's worn through the loom, and most certainly worn through the wire jacket. Lift the wires up gently and they will most likely be worn through. Want proof that this can happen? Here you go https://dodgeforum.com/forum/2nd-gen...ise-speed.html
You can also look through this https://dodgeforum.com/forum/2nd-gen...agnostics.html
Old Oct 15, 2010 | 07:34 PM
New 96's Avatar
New 96
Holy Crap! Its all there . Its going to be a long Day tomorrow !! Thanks Everyone for all the help. I'll be sure to let you guys know what I did tomorrow
after she's all put back together.
Old Oct 15, 2010 | 07:46 PM
zman17's Avatar
zman17
Do the Gov pressure sensor and the Gov solenoid too. Adjust the rear band while the pan is off as long as you are you confident enough and have the right tools to do it correctly. After you put the pan back on, adjust the front band, as long as you are confident enough, and have the right tools!
Old Oct 15, 2010 | 08:08 PM
New 96's Avatar
New 96
I just got off the phone with my Cousin, he has all the correct tools for me to use. I have no problem with making the adjustment. Looks like I'll be broke again till next payday..
Old Oct 16, 2010 | 05:20 PM
New 96's Avatar
New 96
Update #1: removed Tranny pan and gasket.
removed Governor solenoid and sensor Cleaned them inside and out with brake cleaner.
removed Tc Lock down and OD Solenoids Cleaned them inside and out.
Went over Wiring harness to check for broken or missing insulation
trimmed small amount loose wire cage from Harness.
Reinstalled all components .
Have not adjusted Bands yet as my cousin has not been home all day due to going to car shows.
So this will continue into tomorrow before I can put the rest together , filler up and give it a test run.
Old Oct 17, 2010 | 03:23 PM
New 96's Avatar
New 96
Well the saga continues. You'd figure I could find a #13 E-type socket all the sizes around it NO PROBLEM!!! Ugggghhhh
Old Oct 18, 2010 | 03:45 PM
New 96's Avatar
New 96
Ok Final update: Wound up using a 11/32 12 socket adjusted both bands
added 5 qts, of New Atf+4 and a new filter. Took the truck out for a spin.
I just must be lucky she shifted like a dream! all gears no problem.No strange noises ( except for the front end) Now if I can just get it to run right. Still missing like crazy!!!!
Old Oct 18, 2010 | 09:04 PM
J415's Avatar
J415
When was the last time you had a tune up? Could also be a clogged cat or the dreaded plenum.
