door buzzer (how to delete)
Old Oct 20, 2010 | 12:15 PM
My key buzzer works.... but, my headlights are still on buzzer does not.......
Old Oct 20, 2010 | 01:43 PM
southern13guy's Avatar
southern13guy
Is there any way to replace the buzzer with something less annoying? I feel like I get a question wrong on a game show every time I open my door. I've been living with it since I got my truck a long time ago, but it'd be nice to change out.
Old Oct 20, 2010 | 04:39 PM
DodgeTheFather Ramthe Daughter's Avatar
Thanks guys it was fuse 13 took it out and buzzer went off right away and everything else still works
Old Apr 4, 2013 | 04:39 PM
NickRayhall's Avatar
NickRayhall
I took that black box thing out and the radio stopped working so I plugged it back in and now the radio still does not work. Any ideas?
Old Apr 4, 2013 | 05:45 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Check all the fuses. Including the special looking ones.
Old Apr 4, 2013 | 09:00 PM
dhvaughan's Avatar
dhvaughan
what year is your truck.
if you removed the CTM that was a major mistake....
Old Apr 4, 2013 | 11:41 PM
gdstock's Avatar
gdstock
I am kind of wondering why you did that?
Old Apr 5, 2013 | 01:30 AM
dman12323's Avatar
dman12323
You fixed it And then you took another fuse out? And now the radio wont work. Hopefully it isnt the CTM. But im curious to find why you took the fuse out?
Old Apr 5, 2013 | 07:22 AM
Spillage's Avatar
Spillage
Pull the buzzer, pry the case apart and remove the thin steel disc... put it back together and reinstall.
This way it all thinks it is working, but without the diaphragm there is no noise.
Old Apr 5, 2013 | 07:13 PM
dhvaughan's Avatar
dhvaughan
Originally Posted by dipsherry
how do you get rid of the annoying buzzer on a 94 ram i am talking about the one that goes off when the driver door is open
a much easier solution than all the BS above is to remove the clamshell covers around the column/ignition switch, and unplug the 2 wire connector from the switch.
i've learned that the hard way.
