2001 Dodge Ram P/U 1500 2WD Wheel Hub
Old Oct 16, 2010 | 09:16 PM
ngil48's Avatar
ngil48
Default 2001 Dodge Ram P/U 1500 2WD Wheel Hub
My ABS & Break Light Came On, I Started Hearing A Rubbing Noise On Drivers Side Front Wheel. I Pulled Wheel Off And Found That Bearing Were Shot. Went To Replace Hub And Found I Couldn't Break The Axle Nut Loose. I Checked Threads And seemed To Be Right Hand Thread !! Any Suggestions ??? Thanks
Old Oct 17, 2010 | 09:38 AM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome To The Site. I Will Move This Thread To The Second Generation Ram Section,
FF
Old Oct 17, 2010 | 09:42 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Soak it good with penetrating oil and get a 3/4" drive breaker bar and a 3 foot cheater pipe. If that does not work, a torch will.
Old Oct 17, 2010 | 09:51 AM
dhvaughan's Avatar
dhvaughan
a big 3/4 in impact wrench works best. a long pipe and muscle is next best. a nice, dangerous, killer style shade tree method is to wedge the breaker bar against the ground and drive forward or backward to loosen the nut. use extreme caution and keep the children away, as this can break tools in a violent manner and with great satisfaction.
if you don't have any of these, take it to a tire shop and have them break it loose, then apply antisieze and reinstall the nut but not quite so killer tight.
Old Oct 17, 2010 | 09:53 AM
dhvaughan's Avatar
dhvaughan
ngil, welcome to df. my son and daughter in law live at N Augusta, right under channel 12.
Old Oct 18, 2010 | 09:59 PM
ngil48's Avatar
ngil48
Ahhhhhh, My Wife Used To Work Across The Street From There At Communigraphics
Old Oct 18, 2010 | 10:04 PM
ngil48's Avatar
ngil48
Thanks All, I Finally Broke It Loose, But Still Had To Get A Wheel Puller !!!
Old Aug 15, 2011 | 08:34 PM
skydog's Avatar
skydog
Themmm
