4 low question, should I worry?
Old Oct 18, 2010 | 04:16 PM
duneslider's Avatar
duneslider
I have always had the best luck when I am rolling slowly,1-3 mph at most. You shouldn't had to yank it hard but just a nice firm pull.
Old Oct 18, 2010 | 04:35 PM
unsivil_audio's Avatar
unsivil_audio
Originally Posted by Hahns5.2
With and auto I'd try shifting in park, in neutral the output shaft can still spin I believe.
I'm 99% sure thats wrong (and backwards). In "park" the output shaft is still engaged, while in neutral it actually disengages on the transmission. Which is why factory manual says to put it in neutral to shift from 4hi to 4lo.
You can cause damage to your transfer case doing it any other way.
Old Oct 18, 2010 | 05:10 PM
Hahns5.2's Avatar
Hahns5.2
In park, the output shaft cannot spin, that's why your truck won't roll, in neutral the output will spin with the engine running if there's nothing holding it still, shifting the T-case into nuetral, which you do when shifting to 4 low, allows to output shaft to start spinning, making getting it into low range difficult or impossible if you do it slow as others have described.
Old Oct 18, 2010 | 09:36 PM
98BlueSport's Avatar
98BlueSport
I go into 4-hi, then stop the truck, put her in neutral, then slam her into 4-lo, just did it yesterday, and I've never had a problem
Old Oct 19, 2010 | 10:23 AM
I generally have the truck rolling at 1-2 mph, trans in neutral, and just pull the lever back sharply. Works fine.
Old Oct 21, 2010 | 01:57 AM
Jr. Mechanic's Avatar
Jr. Mechanic
The proper procedure is to be rolling 1-5mph in neutral, and give it a good hard yank to 4 low without pausing in neutral. A little grinding is completely normal and isn't really a bad thing.
