Transfer case fill plug stripped
Old Oct 18, 2010 | 09:06 PM
MilesBFree's Avatar
MilesBFree
I can't tell from the pics if it is deep enough to use an EZ Out on it?
Old Oct 19, 2010 | 06:17 AM
MaxPower1971's Avatar
MaxPower1971
Originally Posted by calgaryman
I will not be putting another stock aluminum plug in. I will look at the local hardware store for a bolt with a (i believe) 22mm course thread.
Careful with that....metal and aluminium don't react to heat the same way and it may cause a leak. I never tried it myself, but I would really monitor it afterwards if you go that way.
Old Oct 19, 2010 | 12:51 PM
calgaryman's Avatar
calgaryman
Very good point! Never thought about that.
Old Oct 19, 2010 | 04:38 PM
MilesBFree's Avatar
MilesBFree
Galvanic corrosion would be a concern too. But if you use something like Loctite (the kind made for parts that need to be removed frequently) it should act as an insulator.
Old Oct 19, 2010 | 04:41 PM
Gord.'s Avatar
Gord.
+1 on that...my 94 is 3/8 and my 05 is metric.
Odd, my 95 has a large hex head, not an allen. Maybe my plugs have been replaced at some point in it's past
Gord.
Old Oct 19, 2010 | 04:43 PM
zman17's Avatar
zman17
Retired Moderator - RIP
A regular most likely will not work anyway, it needs to be pipe thread.
