ABS/Parking Brake Issues.
Old Oct 19, 2010 | 02:37 AM
CarvzRam's Avatar
CarvzRam
Default ABS/Parking Brake Issues.
Hello, All.
Wondering if anyone could help me shine some light on the situation. I have a 1996 Ram 1500, 5.2L. The ABS/Parking brake light stays on, And On occasion when I hit the brakes, My abs will kick in, then both lights turn off, once going again they usually come right back on. The brakes, and rotors are all fine not warn or warped. Truck stops fine, No issues. And the axle seals don't appear to be leaking.
Wondering, what course of action or where I should start looking before I have to open up the wallet. Thanks for your time, And your help.
Old Oct 19, 2010 | 10:18 AM
What year truck? RWAL, or 4WAL? Does your speedometer work right?
Old Oct 19, 2010 | 05:16 PM
zman17's Avatar
zman17
Retired Moderator - RIP
What year truck?
Somebody needs glasses!
Old Oct 19, 2010 | 05:49 PM
That wasn't there the first time. Honest.........
As it's a 96..... more than likely RWAL, so, best guess would be the Rear Wheel speed sensor in the differential.
Old Oct 19, 2010 | 06:47 PM
zman17's Avatar
zman17
Yea right! I don't see where he edited his post! LOL
Old Oct 20, 2010 | 01:28 AM
CarvzRam's Avatar
CarvzRam
Hah, Yes it's been there the whole time!!! but you have helped so I won't hold it against ya!!
But yes it's a 4x4 for got to mention, and has a manual transmission. But thanks for your reply I will look into the Rear Wheel speed sensor first thing tomorrow.
Old Oct 20, 2010 | 01:47 AM
DodgeTheFather Ramthe Daughter's Avatar
my 99 ram 318 4x4 does the same thing when u figure out the solution please post so i can fix mine also
Old Oct 20, 2010 | 08:26 PM
VEETEN's Avatar
VEETEN
Have you bled the brakes?
Old Oct 22, 2010 | 01:55 PM
CaptnTony's Avatar
CaptnTony
I just replaced my ABS Speed sensor! Do as the various forums say: DO NOT HIT THE SENSOR WITH ANYTHING (not even a tap!)
Mine snapped in half flush with the differential. Much swearing and frustration ensued. My ABS and Brake lights didn't come on at all (my speedo went south on me). When this sensor snapped, you guessed it, I now had no speedo AND an ABS and Brake lights on.
It's still a DIY job (IMO), but be very careful trying to get that thing out of there. If it is corroded onto the differential a bit, I'd suggest a super small flathead screwdriver tapped EVENLY around it to loosen it up a bit. Then lift and wiggle. If I hadn't broke it, it would have been a 10 minute job to pull and replace it (and I have next to no mechanical skills, learning on the fly).
Good luck. (the speedo, btw, was controlled by transmission speed sensor. Another 5 to 10 minute replacement job with a bit of splicing needed in my case).
