Idle speed problem
Old Nov 23, 2010 | 07:51 PM
  #101
ibaezpardo's Avatar
ibaezpardo
This is a copy and paste from another site about "no bus " message. I just found it. Maybe is useful . Tomorrow I will check the conections:
eans that the communication system between the computers has stopped working.
Hi I have a 2000 Ram 1500 that had the same problem. For me in the Electrical Power Distribution Center ( The fusebox located in the engine compartment ) I have one big connector with a screw down through it that loosens or tightens the connection. Well for some reason that connector wasn't making good contact with at least one or 2 of the pins. I took that off, cleaned it up, and put it back on and everything worked fine. I'm going to clean it better with contact cleaner and coat it with some dielectric grease and see if it stands the test of time. From what I've gathered from many peoples posts is that this specific problem generally seems to be some kind of electrical contact problem and not the Computer or any other major part. Hope this helps someone.
Answer
I had the same "no bus" all gauges dead on my 2000 ram 1500. after looking at all the different answer posted I tried all of them and the one that worked. Was disconnecting the main plug held down by a screw in the fuse box on the engine compartment. I disconnected, blew the plug and the connect with compressed air, plug it back in tighten the screw and my truck is fine again. Everyhing works as it should. thx
Answer
My father in law just had this problem and discovered, with the help of our local mechanic, that there was a short (or a loose connection) in the steering column, possibly caused by the fact that my father in law adjusts the steering wheel every time he gets in or out of the truck. The wires in the steering column are bound quite tightly, and do not allow for the vertical movement of the steering column. Total cost of the repair was $60 cdn. and a case of beer.
Answer
your computer is dead.
a "bus" is what the main information transfer lines in a computer are called.
"no bus" means no information transfer.
that one is gonna be SPENDY. most likely a couple thousand dollars.
Answer
This does not have to be a computer problem. This can also indicate a loose fuse or a simple bad connection. The bus is simply the ground for the electrical devices in the vehicle. It's a fundamental rule: go for the simple stuff before you spend a pot of money on tthe complex.
Answer
Had a similar problem and the parking brake was the problem and needed adj-. A simple nudge untill hearing the parking brake "click" was a quick temporary fix. Only difference was my truck would not start untill this was done.
Make this simple for everyone NO BUS gauges not working is a aggrevating problem. However when you fix it you'll kick your self for how easy it was and wont cost you but maybe 5.00. heres the basic your main fuse panel under the hood has a screw in it with a huge contact. that contact has gone bad/ dirty take out the screw blow out the contact with compressed air pack it with electrical grease put it back in put the screw in TIGHT HAND ONLY and watch all your gauges come back to life. I got a great mech here where i live and after 2 diff dealerships telling me buy a new cluster i knew someone was full of it. then one said my brain was dead . MINI NEWS FLASH IF YOUR BRAIN IN YOUR TRUCK IS DEAD YOUR TRUCK WILL NOT START! again very simple 30 mins fix had this problem off n on for 6 years in my 99 ram which i still have and drive on weekends mine is 1999 V-6 with a super chip i take out to joy ride. do what i said above an your problem will be solved. i haven't had another issue with mine in over 2 years and have gone about 14000 miles without gauges failing
Answer
For me on a 99 2500 dodge ram with NO BUS
Dodge dealer had it 5 times & said it was fixed, would last from one week to about a month. Then they said I needed a new instrument cluster that they would sell me for $1200.00. I did not do that and I was going to fix it myself, it was the connectors on the back of the instrument panel. I took the instrument panel out then removed the wiring connectors from there holders in the back of the dash. Then I put the instrument panel back in on an angle so I could get my hand in behind it to hook up the connectors on the back of the instrument panel then pushed the instrument panel all the way in, put the screws in. I have had no trouble with it since.
ANSWER:
I have a 2004 Dodge Ram 1500, and I have tried all of the above, mine reads "no bus" none of the gauges worked or the windshield wipers. I found my problem to be in the ignition switch, you just have to work with the key (jiggle it while still in the switch) a little bit and all the gauges will start working again. there are two parts to the switch the key part and the electrical part. all of the electrical for the gauges runs through the switch. It has just turned over 40,000 miles and the warrenty has ran out on it.
ANSWER:
I have a 2000 Dodge Ram 1500 Sport. The power distribution connector is located under the dash next to the parking brake instead of the engine compartment. I cleaned the connector and it still didn't work but while working on it I wiggled some wires around it and my instrument cluster began working for a while. TurnS out that the bus wires to the fuse box were jammed in the parking brake lever. Cost to fix: nothing.
Old Nov 23, 2010 | 09:05 PM
  #102
You have more than one issue going on there. I would begin to suspect failing cam/crankshaft position sensors...... The "no bus" thing means the PCM isn't speaking to the instrument cluster. (it got mad, and shut itself off) Check wiring for crank position sensor, and cam position sensor. I would suspect that one or the other is grounding out, or, the sensor itself is failing.
Old Nov 23, 2010 | 10:39 PM
  #103
ibaezpardo's Avatar
ibaezpardo
Thank's. I will check everything tomorrow and let you know..
Old Jun 19, 2011 | 01:47 AM
  #104
ibaezpardo's Avatar
ibaezpardo
Post
"NO BUS" problem solved. PCM was replaced.
Sorry to get back to the 0505 code problem. Still no fixed.
-4 IAC changed
-1 PCV changed
-1 TB cleaned
-8 spark plugs changed
-1 tranny rebuilt
-1 TB gasket added
-2 O2 sensors new
-1001 nights reading posts about idle speed
Same problem. 1500 RPM at idle and 0505
Somebody wrote something about replace the TPS. Did you noticed wrong measures on it before replacement? Mine looks good with a meter.
Old Jun 19, 2011 | 11:02 AM
  #105
Start tracing wires from the IAC, to the PCM. Sounds like you have a short/open there somewhere.
