Idle speed problem
Old Oct 30, 2010 | 03:02 PM
  #21
ibaezpardo's Avatar
ibaezpardo
Question
Replaced MAP sensor. Same voltage measures. Trip from Miami to Key Largo. 60.6 highway miles at 70 mph almost all time. 3.2 gallons . Almost 20 mpg but still the same problem. When stop, RPM are between 1000~1500. If I wait at "idle" speed around 10 minutes, then RPM drops to 600 RPM.
I heard a vacuum leak at passenger side inside hood but is only at the moment I stopped but disapears inmediatly
Old Oct 30, 2010 | 03:26 PM
  #22
merc225hp's Avatar
merc225hp
I don't know if this will help, but try disconnecting the big vac line to the brake booster and plug it, Check the hose for cracks, test. remember you will have "NO" power brakes with the vac line disconnected.
Old Oct 30, 2010 | 07:13 PM
  #23
ibaezpardo's Avatar
ibaezpardo
Question
Checked voltage from the O2 sensors: between the normal range.
Scan tool: still showing P0505 idle control malfunction, both O2 sensors showing "inc"
I don't know where to troubleshoot now??? I need some help
Old Oct 30, 2010 | 07:37 PM
  #24
ibaezpardo's Avatar
ibaezpardo
Noticed it doesn't matter how long is running at idle, never increases the RPM (600 RPM) even at operation temp.
When is running at high RPM, then, when you stop, RPM will increase to 1000~1500. Passed 10 minutes, star to decrease until 600 RPM again.
Heard some vacuum leak but tested lines with a vacuum pump and didn't find it...
Old Oct 31, 2010 | 02:08 AM
  #25
Sixtysixdeuce's Avatar
Sixtysixdeuce
Originally Posted by ibaezpardo
Yesterday I checked the TPS and looks OK. Voltage increases at center wire with the throtle advance.
I checked the MAP sensor and voltage should increase with RPM but is not. I bought a new one today and will install tomorrow morning. I will test and post results
It really doesn't work that way. It should be close around 4.5v at 0 vacuum, about .5v at full vacuum (~25-30 in hg). But vacuum is not in linear proportion to engine RPM; If it were, there'd be no need for a MAP sensor.
The only correct way to test a MAP is with a manual vacuum pump that has a gauge.
I still believe you have a vacuum leak. Did you check that port I mentioned before?
Old Oct 31, 2010 | 09:12 AM
  #26
ibaezpardo's Avatar
ibaezpardo
Originally Posted by Sixtysixdeuce
.... you need to start looking for vacuum leaks. 1,000 is very high for a warm engine. There's a vacuum port on the side of the manifold that is capped from factory on most engines, but that cap deteriorates (or gets eaten my rodents), and causes a leak. And there are other places that it could be leaking vacuum as well. The easiest way to find a vacuum leak is with a can of carb clean or brake clean sprayed around the intake and vacuum hoses while the eninge is idling. If it has a leak, pulling in the cleaner will cause an over rich condition and drop engine RPM.
However, before you do that, you mentioned a whistle at part throttle. Sounds like your air horn gasket is shot. Replace that before you go looking for vacuum leaks, as it'll give you a false symptom and send you on a wild goose chase.
I installed a new gasket (never was there) but I can't find that port. I will take a look right now
Old Oct 31, 2010 | 09:16 AM
  #27
ibaezpardo's Avatar
ibaezpardo
I did it yesterday with a vacuum pump and holds the pression.Then, I installed back the original part ( I installed a new MAP sensor but is $68, if mine is OK I'm planning to keep it)
Old Oct 31, 2010 | 11:09 AM
  #28
Sixtysixdeuce
I don't mean checking it for a leak, I mean voltage sweeping it. You watch the signal volts on a scanner or a DVOM while you slowly increse vacuum. As vacuum goes up, voltage goes down.
Old Oct 31, 2010 | 11:20 AM
  #29
zman17's Avatar
zman17
Retired Moderator - RIP
If your HVAC system works fine and cruise control works fine, odd are in favor you don't have a vacuum leak.
Old Oct 31, 2010 | 12:29 PM
  #30
Sixtysixdeuce
It'd take a pretty massive leak to bleed of enough vacuum that those things don't work. Like, big enough that the engine won't idle.
The fact that they still function fine just means that the leak isn't the vacuum line into the cab or to the CC module.
I couldn't find any images that actually show that port I'm talking about, but snagged this one and put an arrow where you need to look:
