Which Spark Plugs to get???
Old Oct 20, 2010 | 02:03 AM
DodgeTheFather Ramthe Daughter's Avatar
Default Which Spark Plugs to get???
Im getting a Tune Up kit for my 99 ram 318 4x4 and was wondering which spark plugs are the best ive read good things about the E3 plugs and the Autolight iridium plugs wondering which are better?? also do plug wires really matter if i get the MSD wires or the Bosh wires or even the cheap ones??
Old Oct 20, 2010 | 02:38 AM
UnregisteredUser's Avatar
UnregisteredUser
If you've got the factory coil your best bet is to avoid the expensivum (platinum or iridium) plugs which likely won't fire properly on the lower voltages produced by the factory coil. NGK V-Power and the Autolite 3923 seem to be the best bets.
The cheesier wires will have to be routed IAW the TSB for plug wire routing or they'll be prone to inductive cross-fire. Whether you'd rather spend more or just take more time doing it is something only you can decide.
Old Oct 20, 2010 | 02:41 AM
CPTAFW163's Avatar
CPTAFW163
Oh, I thought you needed to route the spark plugs by the TSB even if they are 8mm+ wires.
Man i am still spending time to route them correctly!!
Wait, I have headers, I still need to have them neat.
Old Oct 20, 2010 | 04:20 AM
bigslick050's Avatar
bigslick050
Whatever you get, make sure they are NOT E3's. ALOT of DF memebers have had problems with this plug including myself. Put them in and instantly got 3 cylinder misfires.
Get Champs Copper Tip
-or-
NGK Iridiums
-or-
Autolite 3923
Old Oct 20, 2010 | 06:26 AM
Yellow99's Avatar
Yellow99
not to ***** the thread but what coil should i get if i want to upgrade that too
Old Oct 20, 2010 | 11:03 AM
talon6's Avatar
talon6
get the cheap stock champion copper plugs. i have never heard of anyone having problems with them. and they are only like 2$ a plug.
Old Oct 20, 2010 | 11:17 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Autolites won't go well with my truck. Fuel economy goes downhill and I get a misfire on #5. The truck also runs sluggish as well. Stock Champions FTW!
Old Oct 20, 2010 | 12:10 PM
Sheriff420's Avatar
Sheriff420
My truck likes the Bosch platinum +4 plugs.
Old Oct 20, 2010 | 01:11 PM
talon6's Avatar
talon6
i also got misfires with the autolites. ran great at first. then a couple thousand miles and it all started.
Old Oct 20, 2010 | 01:48 PM
dodgeram07's Avatar
dodgeram07
Stock Champions for no problems
