i hate my dually wheel cylinders
Old Nov 5, 2010 | 06:38 PM
  #21
Maxx_Magnum's Avatar
Maxx_Magnum
Originally Posted by matty675
i adjusted them and it was perfect, no wheel lock. then it progressively rebounded to being just as bad as it was, why wont it stay adjusted right?
Are you sure you re installed everything as it came out? This kinda sounds like you got them backwards and it's adjusting them too tight..... The adjusters should tighten up when you apply the brakes in reverse only
Old Nov 5, 2010 | 06:51 PM
  #22
matty675's Avatar
matty675
the adjuster lever is to the rear of the drum, as is the star, on both sides, right?
Old Nov 6, 2010 | 09:11 AM
  #23
Sheriff420's Avatar
Sheriff420
This is what it should look like.
If you had the adjuster on backwards then the adjusting arm wouldn't reach the star.
Old Nov 6, 2010 | 11:18 AM
  #24
matty675's Avatar
matty675
mine is defferent. im guessing it changed after '97? the adjuster arm contacts the top/side of the star wheel, not the bottom, nor is the spring in that position on the adjuster arm. both adjuster arms are toward the rear of the truck, does that sound right?
could i need a hardware kit with springs adjuster components and what not?
Old Nov 6, 2010 | 11:26 AM
  #25
zman17's Avatar
zman17
Retired Moderator - RIP
Yes, the arms are both rearward as are the adjusters. It is also recommended to replace the hardware kit. Next time, do one side at a time so you can look at the other side for reference. And yes, depending on the year, there are some variations to the setup.
Old Nov 6, 2010 | 11:41 AM
  #26
Sheriff420's Avatar
Sheriff420
Crap, I forgot that the 97 was different.
I think Laramie has a picture of his 97.
Old Nov 6, 2010 | 12:13 PM
  #27
zman17's Avatar
zman17
The Haynes manual does also, but if "we" don't have one or have not looked, then I guess there's nothing more to say
Old Nov 6, 2010 | 01:09 PM
  #28
matty675's Avatar
matty675
haha i have looked!! all seemed well according to the picture. so i will do the hardware kit with springs and adjusters. could bad drums or shoes cause this?
thanks anyhow sheriff
Old Nov 6, 2010 | 01:55 PM
  #29
UnregisteredUser's Avatar
UnregisteredUser
Out-of-round drums can, certainly. It'd probably be best to have them checked and turned or replaced as necessary before spending any time or money on other things.
