i own 97 half ton with 6 in suspension on 35's i recently started to get dws (3times ) bad ones tho an i noticed that y trac bar moves side to side when i turn and the bolt also moves to i kinda figured it wasnt to good lol but didnt both with it till this happened what do i need to do nething can help and i also no that shoxs are bout shot if that hels with dws
sorry didnt relize i was leaving letters off my words but when im driving my truck and drive across bumpy roads my truck begins to shake like crazy and i geuss its what they call death wobbles and i noticed that my track bar moves from side to side when i turn the stering wheel and where its bolted to the frame the bolt moves and i no that it shouldnt be doing that lol an idk if the movement of it has made the whole for the bolt bigger but thats my geuss and i dont realy think there is a problem where the track bar and pitman arm connect but maybe its just bushing notsure nething will help
what do i do if the whole on the bracket of the frame is bigger then it should be from the movement of the track bar, because the bolt moves about a half inch or so when i turn the wheel?
should i get a bigger bolt so if it was to move again there wouldnt be so much play between the bracket and bolt or will the bushing come into play there to help keep it in place ?
