door locks go up but not down
Old Oct 23, 2010 | 10:55 PM
dipsherry's Avatar
dipsherry
Default door locks go up but not down
my door locks just started acting up today and go up but not down u can hear them attempt to go down but they just stay stuck up. I took the door panels off to see if they were stuck or dragging but they weren't so i don't know where to look next
Old Oct 24, 2010 | 07:44 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Could be the driver side switch I suppose. Does the passenger side work fine when you use that switch?
Old Oct 24, 2010 | 10:13 AM
dipsherry's Avatar
dipsherry
nope neither the driver side or passenger side switch work. I just would find it weird that they worked i went inside for 10 minutes and they dont. I cant imagine them both going bad at the same time but i checked wiring and dont see how they could be wired together so i guess its off to the junk yard for some new switches
Old Oct 24, 2010 | 01:38 PM
merc225hp's Avatar
merc225hp
Mine does this at least once a month no big deal, they should reset after a couple of times of running the truck. Tip don't leave your keys in the truck, mine will lock itself every once in a while for no reason.
Old Oct 24, 2010 | 02:02 PM
zman17's Avatar
zman17
Well, there is a reason , one of the switches is probably bad. Most likely the driver side. It get's the most use, water and dirt.
Then again, the passenger side hardly ever gets used, so it might have an internal corrosion problem.
Old Oct 24, 2010 | 02:19 PM
merc225hp's Avatar
merc225hp
I agree, I know it's not any of my switch's I am thinking along the line that it lies in the pcm functions, I which case I will live with it.The trucks done it pretty much since new. I am not saying that this is it for sure but before he goes running for parts he should do as you suggested and check his switches, Try your key in the door lock and cycle it a couple of time's and see if that helps, Could be old sticky grease on the door locks that are binding it up.
Old Oct 24, 2010 | 03:09 PM
zman17's Avatar
zman17
I could be wrong and probably am, but,I don't think the PCM has anything to do with it. I do agree on your other point's though. Beside's, if he can get the switches at a U pull it JY, they might be 5 bucks total. Atleast they can be eliminated as the problem.
Old Oct 24, 2010 | 04:07 PM
charlie1935's Avatar
charlie1935
My door locks quit working a while back and I pulled the fuse, it was good so put it back in. They have worked ever since. Guess the blades on the fuse needed cleaned.
Old Oct 24, 2010 | 04:45 PM
merc225hp's Avatar
merc225hp
zman17 you are right and I am wrong, for some reason I thought is was part of the pcm functions, But I just looked at the bible and It does not control the door locks. So now I am curious as to what does control the door locks?
Old Oct 24, 2010 | 06:15 PM
dipsherry's Avatar
dipsherry
well i got new switches from my local u pull it and no luck i have cleaned the locks and i have cycled the key in the door locks i dont have a clue where to look next
