Adjusting Instrument Cluster Needles
Anybody got a quick way to adjust the RPM, Speedometer, Gas, Voltage, Oil Pressure, and Temperature needles? Removed them to do some work, just need to get them back to normal.
Here is description of the dakota calibration. The cluster in the Ram works the same.
http://faq.dakota-truck.net/Electron...struments.html
EDIT: Forgot that you can also use same OBDII Reader to see live values. You can compare them with the instrument values to set the needles to the correct position
Thats right. This will only works on 1998 and newer 2.gen Rams.
