how to open CAD? are the holes threaded?
Old Oct 25, 2010 | 06:28 PM
Arachnyd's Avatar
Arachnyd
Default how to open CAD? are the holes threaded?
I sheared off three of the 4 cad housing bolts. I'm starting to get desperate and frustrated.
I used a pry bar and put a lot of pressure on it, but it still won't pop. Wonderinf if its because of the 3 bolts which were sheared. Are those holes in the cover part threaded too?
If not, do I just need to wail on it with a hammer and a pry bar to get that to pop?
Also, when I put it back on, I'f I cant get the bolts out, I'm going to just strap it down for now. Do you just use RTV on there like you do on the diff?
The haynes manual is useless here...
Old Oct 25, 2010 | 06:35 PM
zman17's Avatar
zman17
Retired Moderator - RIP
It's common for the CAD bolt's to break. Pry harder if the heads of the bolts broke off . The bolt's are rusted to the CAD housing and/or the OEM gasket is stuck.
Old Oct 25, 2010 | 10:44 PM
matty675's Avatar
matty675
your supposed to use a cork gasket, but i guess rtv would do, so are you giving up and doing away with 4wd or what?
Old Oct 25, 2010 | 11:05 PM
dhvaughan's Avatar
dhvaughan
cad cover is not threaded. just regular open holes.
i've used rtv for the cad gasket and diff covers many times, but always with bolts to hold the cover on.
you really should drill out the broken bolts and install new ones. the shaft and fork and stuff is attached to the cover, and if the fork was to bind up, it might pop the cover off.
Old Oct 26, 2010 | 10:19 AM
95RAM360's Avatar
95RAM360
i had my CAD off 2 days ago, my bolts are threaded in...ive taken CAD off like 15 times in the past year, never had a problem with the bolts or gasket (yes i used cork as well, got it from dealer)...its a 13mm socket if you didnt know......
Old Oct 26, 2010 | 05:41 PM
zman17's Avatar
zman17
The CAD housing itself is not threaded!
