how good r u at engine diag
Old Oct 15, 2010 | 07:31 PM
97ram5.2's Avatar
97ram5.2
Default how good r u at engine diag
alright i have a 2000 dodge ram 360 engine in my 96 ram recently the 2 lifters in number 8 cylinder collapsed and it was smoking and rapping real bad so i pulled the intake raplaced lifters and push rods and reasembled when i fired it back up there was no more noise but still smoking real bad engine dosnt miss or studder just smokes real bad i let it run for about 15 minutes making sure it wasnt just spilled coolant or oil but it still pours smoke out so i did a compression test and have about 120 psi across the board but it seemed like the pistons have a film of oil on them so be for i pull the intake off any ideas? ive done intakes on my other dodges before and never had any probs so any ideas would b nice ...........thanks
Old Oct 15, 2010 | 07:56 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Bad valve seals or blown plenum gasket.
Old Oct 15, 2010 | 09:05 PM
97ram5.2's Avatar
97ram5.2
i replaced the plenum gasket when i had the intake off would the valves seals go bad that fast? in like 2 days?
Old Oct 15, 2010 | 09:54 PM
dhvaughan's Avatar
dhvaughan
when did you replace the valve seals ? you didn't say you did.
try to use a period every once in a while, that hurts my eyes.
Old Oct 16, 2010 | 01:45 PM
97ram5.2's Avatar
97ram5.2
srry about the punction, i didnt replace the valve seals i meent 2 days ago it started smoking and i assumed it was because the lifter were collapsed. But now i fixed that and it still smokes thats why i was asking if the valve stem seals could go bad that fast.
Old Oct 16, 2010 | 01:51 PM
zman17's Avatar
zman17
The lifters have nothing to do with why it smokes! What color is the smoke?
Old Oct 16, 2010 | 07:01 PM
97ram5.2's Avatar
97ram5.2
like a whiteish blue and smells like oil but the color of the smoke looks like burning anifreeze but the plugs are all a dark color and top of the pistons have a slight coat of oil,not washed clean like they normally do when a head gaskets blown ya know.
Old Oct 16, 2010 | 09:06 PM
dhvaughan's Avatar
dhvaughan
so is this the story ?
up until a few days ago everything was normal. no tapping, no smoke.
then suddenly, you have tapping and smoking.
you pulled the valve covers and intake, and replace both the lifters and pushrods on #8 and the plenum gasket. nothing else, and put it back together.
the tapping is now gone.
but its still smoking.
just thinking out loud. oil in the cylinder would have to come from leaking headgasket, leaking plenum, rings, valve seals and/or valve guides or cracked head into an oil space.
so what lead up to the problem? normal driving or high rpm or what?
it seems odd to me that 2 lifters would suddenly fail.
fess up to the whole story so we can figure it out.
Old Oct 17, 2010 | 12:42 AM
99dodge318's Avatar
99dodge318
^ wow this guy watches too much CSI! ^ lol
Old Oct 17, 2010 | 04:22 PM
97ram5.2's Avatar
97ram5.2
i was up on and old stripping road going to pull a buddy out of a mud hole, and when i got there it was tapping. So some1 else came and pulled him out cause i wasnt gonna beat my truck with it tapping, and by the time i got home it was smoking . I ripped the intake back off it today and everything looked okay, and i inspected everything real good and nothing looked abnormal. i have true duals so id have to blow both head gaskets for both sides to smoke correct? Even if my compression is good could it still b smoking from the rings? this thing smokes bad wiorse then anything ive ever seen.
