od switch questions
Old Oct 25, 2010 | 09:30 PM
dipsherry's Avatar
dipsherry
Default od switch questions
if i hit my od switch it does nothing no lights no anything. Is there a light on the dash that is supposed to come on? aslo i have checked the plug in and it is connected
Old Oct 25, 2010 | 10:31 PM
redheadhunter21's Avatar
redheadhunter21
its supposed to light, does it turn overdrive off????, I will be taking my foglight switch apart again in a couple days and can take pictures I would assume that the switches are the same.
Old Oct 25, 2010 | 11:04 PM
Gaius's Avatar
Gaius
It's just a momentary switch. I would check to make sure it has continuity to the PCM, and check it by wiring up a cheap switch.
Old Oct 26, 2010 | 01:29 PM
dipsherry's Avatar
dipsherry
no my od does not turn off and i guess i will go out and wire in a switch to see if it will kick out of od with it...
Old Nov 6, 2010 | 11:16 AM
dipsherry's Avatar
dipsherry
ok so i went and pulled my od switch out and i dont have a clue which wires to hook up to a switch...please if someone knows what 2 wires to hook up let me know please
Old Nov 6, 2010 | 11:28 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Why don't you just get a new switch?
Old Nov 6, 2010 | 11:44 AM
dipsherry's Avatar
dipsherry
local scrap yard dont have one and i am supposed to be pulling my car tailer with my dakota on it to a mud fest in the morning. so i am looking to see if i can rig it till i find a new switch on ebay or something
Old Nov 6, 2010 | 12:07 PM
zman17's Avatar
zman17
In that case, you can try this , https://dodgeforum.com/forum/2nd-gen...h-r-and-r.html
Old Nov 14, 2010 | 09:43 AM
dipsherry's Avatar
dipsherry
ok got a new switch still no luck i checked it with a voltmeter and i have a good ground and power coming in so i have no clue what is going on ...does it go to the ecm or what but i still dont have a light on my od switch either???
Old Nov 14, 2010 | 10:08 AM
zman17's Avatar
zman17
NO 4-3 DOWNSHIFT
WHEN CONTROL SWITCH
IS TURNED OFF
1. Control Switch Open/Shorted. 1. Test and replace switch if faulty.
2. Overdrive Solenoid Connector
Shorted.
2. Test solenoids and replace if seized or
shorted.
3. PCM Malfunction. 3. Test with DRBT scan tool. Replace PCM
if faulty.
4. Valve Body Stuck Valves. 4. Repair stuck 3-4, lockup or lockup timing
valve.
And sorry for that wrong link I gave you above.
