Fog Lights Issue
Old Oct 27, 2010 | 01:58 PM
SunhawkRam's Avatar
SunhawkRam
Default Fog Lights Issue
Ok I know you guys know what to do lol I can hit my switch for the fog lights and they will come on. Once I let go of the switch, it will disengage. Should I just replace the switch or what else could be the problem?
Old Oct 27, 2010 | 02:01 PM
Maxx_Magnum's Avatar
Maxx_Magnum
I would say your switch is bad if it's not holding in the on postion when you push it. It's the click on click off type right? That's how mine is but my interior is different than yours
Old Oct 27, 2010 | 03:44 PM
TitanOneSeven's Avatar
TitanOneSeven
His should be the click on click off type. So if it's not staying down then it should be replaced.
Old Oct 27, 2010 | 04:14 PM
hydrashocker's Avatar
hydrashocker
Yep, replace the switch.
Old Oct 27, 2010 | 04:32 PM
redheadhunter21's Avatar
redheadhunter21
Until you get a new switch, you can take the one you have out and take it apart and there is a spring in it if you take the spring out and put the switch back together, you can turn them on just not back off. Thats how mine is, cause my switch had the same problem about 3 days ago.
Old Oct 28, 2010 | 09:49 AM
SunhawkRam's Avatar
SunhawkRam
thank you all I am going to spend the $65 on the switch then....unfortunately!
Old Oct 28, 2010 | 09:53 AM
Maxx_Magnum
Holy crap man! go to a JY and get one for 5 bucks!
