Sonnax or Transgo?
Ok, I have experience with the Transgo TFOD Jr kit for the 46RE, but know almost nothing about Sonnax. It's funny that on DF, Sonnax is all that's preached whereas on the *other* major Dodge forum, the Transgo kit is king.
So, which is better and why?
Well if your talking about the sonnax sure cure kit, I dont think it is a shift kit it is just a couple parts that are known to go wrong on our trannys, where as the transgo TFOD jr. kit is a shift kit.
Best person to ask would be Montec,
The kits are basically identical. From what I understand the only difference is the Transgo kit you drill some larger holes in a couple of placed that the Sonnax kit doesn't. Thus the Transgo kit with the bigger holes oils the clutch plates better which allows them to last longer but at the expense of feeling a much harsher shift.
Someone will correct me if I'm wrong. Aims did a DIY one the Sonnax and explains the differences in there. From what I know, he hasn't had any problems at all with the Sonnax
Trending Topics
Wouldn't say the transgo gives a much harsher shift, but it is firmer and quicker which translates to longevity.
I know almost nothing about the Sonnax kit so that's why I was askin. I'm wanting to eventually swap in an NV4500 because I'm an auto h8tr.
But for now, I figure I might as well install a cheap problem-solver/shift-kit on the next pan drop, since that swap ain't gonna be for a while. Already got the auxilary cooler so I'm set there.
Its a puzzle, that's for sure. Taking notes and pictures is an absolute must if you're a first timer in there. Note the position of all bolts, springs, and especially check *****. Read the directions at least three times, and just before you do another step, check it again and make sure you aren't putting a part in backwards.
Give yourself an entire weekend to do it. If you rush, you'll end up with a FUBAR valvebody and trans in the end.
I recommend using giant white trash bags as a table cover to work on, and gallon zip lock bags to put parts in on disassembly. It really helps you to find lost parts and keep parts that go together, together. Also I'd use a sharpie to label the bags and note any odd steps you had to take to get a part off or how to route a specific part.
and be prepared to cuss, a lot.
