huge question...(youre probly gonna hate me)
Old Oct 29, 2010 | 07:15 AM
redneck_ram's Avatar
redneck_ram
Default huge question...(youre probly gonna hate me)
hey guys..i have a huge question. i know this isnt a ford forum but im not going to go sign up to one just for this question that you guys can probly answer. my buddy has a 93 ranger 4.0 5 speed. last night while driving home he lost every gear except 4th including reverse. have any of you ever had this ahppen to you before? the clutch is brand new, and te only thing i can think of is that its low on fluid cause its got a small leak. again i know its not a ford forum, but any help is appreciated. TIA
Old Oct 29, 2010 | 07:37 AM
mjonesjr's Avatar
mjonesjr
Let me start off by saying, the best Ranger based forum is www.therangerstation.com. I say that not only because I am a moderator there, but it is one of the largest out there.
Now to answer your question.
If it was out of fluid, he would still be able to shift into the gears. Sounds to me that the syncros have gone bad. Best bet would be to remove the shifter off the transmission and look into the syncros and the transmission to see if you can see anything else that might be wrong in there.
Old Oct 29, 2010 | 07:52 AM
redneck_ram
he can still shift into the gears, but it just revs up like he lost the clutch, but the clutch is brand new. all this happened while he was driving home down the highway last night.
Old Oct 29, 2010 | 07:55 AM
95RAM360's Avatar
95RAM360
hows the clutch slave cylinder........my buddy had a 94 Nissan 4x4 5spd, and his slave went bad, and it took out his clutch...it blew the throwout bearing down near the slave fork.
Old Oct 29, 2010 | 07:58 AM
mjonesjr's Avatar
mjonesjr
I doubt it is the slave cylinder, but check for fluid from under the truck. If it was the slave cylinder, it would still go in all gears, just impossible to shift with the clutch.
Check to make sure that the transmission has fluid in it. If it doesn't, then you need to check the gears inside the transmission to see if they haven't been ground off from friction and heat.
redneck_ram
i will have to ask him that. i havent actually looked at the truck yet. im just going off of what he told me.
Old Oct 29, 2010 | 07:59 AM
95RAM360's Avatar
95RAM360
yes it could be the slave, if it goes dry, the prong can get wedged in place, and it will disable the truck from going into any gear.
Old Oct 29, 2010 | 08:12 AM
redneck_ram
he can still put it in any gear, but the only gear that works is 4th gear. all the others just rev like it would if you lost the clutch. so thinking about it now there is no way its the slave cylinder. im thinking like what mjonesjr said, that the tranny lost all the fluid overheated and the gears got ground off.
Old Oct 29, 2010 | 08:48 AM
mjonesjr's Avatar
mjonesjr
If you read what the OP has posted, it in no way could be a bad slave. The OP stated that it would only go forward in 4th gear, but still could shift into all other gears and only rev, then in no way could it be the slave cylinder. If the slave cylinder was bad, when the truck was running you would have to have the engine and transmission running at the same RPM to shift it.
Old Oct 29, 2010 | 10:59 AM
redneck_ram
well i guess this thread was pointless. my buddy and i are just gonna pull the tranny and replace it this weekend.
