4x4 light
Old Oct 29, 2010 | 06:38 PM
minitrucker's Avatar
minitrucker
Default 4x4 light
my 4x4 light keeps coming on at the red light when i drive away it goes out ? when im only in 2wd ? my front axle acuator is also broke also when i slow down i hear a little ticking sound coming from the front end....... thanks
Old Oct 29, 2010 | 06:41 PM
Fix your 4x4 problems...... Sounds like the actuator is 'stuck' in a 'close' to 4 wheel drive position...... Can you tell which side your ticking sound is coming from?
Old Oct 29, 2010 | 06:47 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Look at this http://www.dodgeram.org/tech/repair/..._engagment.htm and the ticking sounds like a ujoint going bad.
Old Oct 29, 2010 | 06:48 PM
minitrucker
drivers side i think..........im ordering a posi lok cable kit..... im glad this isnt my daily driver
Old Oct 29, 2010 | 06:57 PM
zman17's Avatar
zman17
When you install the PosiLok, make sure you block off the vacuum line going to the TC switch.
