Measurements off leveling kit.
Old 11-05-2010 | 08:21 PM
bambikiller3006's Avatar
bambikiller3006
I was going to put them on tonight but a cold front is moving in and I dont deal with cool weather very good but in the morning Ill began the install. not very smart with a computer but ill try my best to figure out how to post pics and get some of info up to benefit yall.
Old 11-06-2010 | 07:24 AM
kman5050's Avatar
kman5050
OK lol sounds good keep me updated
Old 11-06-2010 | 08:10 PM
bambikiller3006
Alright got them put on!! Turns out the 4.5 OD pipe is a little too big for the rubber boot that rides on top the coil. I had to slip the boot over the the pipe on the bottom of the leveling kit and then bolt the spacer to the coil bucket then i used coil spring compressors to get the spring back in. once they was in i jacked up the axle to set the coil back into the boot properly. but other than that they tuurned out great. On the bad note I was in a rush to get finished because i had to help my parents move out of thier house but i did manage to take a few pictures in the process.
Old 11-06-2010 | 08:17 PM
bambikiller3006
Old 11-07-2010 | 05:27 PM
kman5050's Avatar
kman5050
looks good. So you think if it was turned down to like 4.25 it would go on a little easier?
definitely gave me some ambition.
i come from the world of Jeeps and we like to do alot of stuff ourselves. which i see isnt to popular around here lol.
this should be stickied in my opinion lol
Old 11-07-2010 | 05:28 PM
kman5050's Avatar
kman5050
did you keep both larger pieces at 7" diameter?
Old 11-07-2010 | 05:29 PM
kman5050's Avatar
kman5050
and just to add to yours a little bit (and its what i plan on doing. i would have thrown a couple welds on the bolts. Just a bit easier to install. looks like itd be a little difficult to get a wrench or ratchet in there.
Old 11-07-2010 | 06:23 PM
bambikiller3006
Yea if i wouldnt of been in such a rush i would have welded the bolts in but luckly i have some long fingers to reach in and get that back bolt on the coil bucket. I come from the 80s model chevy scene and before that was a YJ and then a Duramax and Tacoma. So Dodge is new to me. but on the good note i went to the Woods today and got about 100 miles on then and im glad i did it myself almost got stuck but thats just part of the fun. I should have measured to see how much lift it gave me but i forgot also... Ive got like 10 inches between tire and fender on top. Tires are BFG AT 33x12.50x15 on 10 wides. but i do think turning them down to 4.25 would be better! As long as it aint too much work to turn them down!! O yea both top and bottom was 7 inches on the rings and they worked fine.
Old 11-08-2010 | 11:02 AM
willstruck's Avatar
willstruck
You should measure how much lift you got. I was thinking about doing spacers to lift my truck, but the coils are so saggy that I'm already probably an inch lower than stock. I wanna know if 2 5/8 gave 2 5/8 of lift, so I can compensate for the old springs.
Old 11-08-2010 | 08:16 PM
bambikiller3006
Ha thats kind of where i lacked measurements at I didnt measure it before i lifted it but to me it seems like 2 and 5/8s gave me 2 and 5/8s so im almost plositive what you put between the coil and the bucket is what youll gain whenever your finished.
Quick Reply: Measurements off leveling kit.
