Projector headlights
Old Nov 5, 2010 | 03:31 PM
aim4squirrels's Avatar
aim4squirrels
I will add that the projector housings don't hold a 9004 bulb. Mine hold a H1 bulb, so if you order a HID kit for your projector housing make sure you know what bulb it uses.
Old Nov 5, 2010 | 04:06 PM
lastrights's Avatar
lastrights
i have projection lights, non hid there still way brighter than stock, and you do have to switch some wiring but there worth it i like em!
Old Nov 5, 2010 | 05:06 PM
ram74jt's Avatar
ram74jt
lastrights- do your projectors use the stock light bulb? I was looking at Anzo projectors that say you can use the factory bulb. I was just wondering how much better then factor that would be.
Old Nov 5, 2010 | 05:31 PM
lastrights's Avatar
lastrights
no the factory plug,plugs into the projector no bulbs
Old Nov 5, 2010 | 06:07 PM
aim4squirrels
My projectors were way dimmer with a halogen H1 bulb. Like not really safe to drive with dim. I don't know how they could be brighter with a halogen bulb, but Ill defer to lastrights on his.
Lastrights, do your projectors have the cutoff shield in them? Where the top half of the beam is shaded?
Old Nov 5, 2010 | 06:31 PM
lastrights's Avatar
lastrights
on the low beam there is a cutoff shield ,is there a way too remove that ? the high beams are on the middle part of the housing that itself you can see for miles!
Old Nov 5, 2010 | 07:12 PM
TheBigRedOne's Avatar
TheBigRedOne
The cutoff shield is what prevents you from blinding other motorists. Don't remove that. I have HID's in projectors in my Expedition and I know that for a factandahalf.
