how to remove stripped/frozen screw in sill plates?
well i need to know to to get the screw that hold the carpet sills out. the are stuck and can not get the to break loose. and i want to pull the carpet up so i can hide all the wires for my amplifer so i can install my sub.
Any ideas
Thanks
Any ideas
Thanks
Drill off the screw head. I tried using an impact driver on mine, and all I succeeded at was ripping out some more metal from the head. Drilled 'em out, and just installed slightly larger screws. Problem solved.
