Towing and engine RPMs
Old Nov 6, 2010 | 08:26 AM
oiler's Avatar
oiler
Default Towing and engine RPMs
I know towing questions have been beat to death, but I am curious about others experience while towing out of overdrive. I tow a 2 horse trailer which is about 2000 # with 2 horses weighing 1100 each. Add 600#s in tack and passengers I'm at almost 5000 #s. The truck has the factory tow package with external trans cooler so its set up for this weight. My concern is that at 60 mph I run at about 2500 rpm. 65 pushes it too 2800 rpm. Is running at these higher rpms safe, or am I pushing too hard for say a 100 mile long trip.
Old Nov 6, 2010 | 08:31 AM
Your engines Redline (RPM at which it starts destroying itself) is 5000 RPM. Cruising at 2200-2800 is just fine. Sure, gas mileage suffers, but, a bit of gas is a lot cheaper than the new trans you would need if you towed in overdrive.
Old Nov 6, 2010 | 10:20 AM
95RAM360's Avatar
95RAM360
a good option would also be to upgrade your gears, that will help with the rpms, and gas milage
Old Nov 6, 2010 | 11:09 AM
redheadhunter21's Avatar
redheadhunter21
No problem as long as the engine stays cool, which at those speeds it shouldnt be a problem
Old Nov 6, 2010 | 09:33 PM
oiler's Avatar
oiler
Thanks for the responses. I'm not sure what gear ratio I'm running, its been over a year since I serviced the rear end so I've forgotten. With my high miles it still will hold 55 on a fairly step grade loaded pretty well. Pulling I can get about 10 mpgs. Thanks, I'll sleep better knowing I'm not hammering my little 5.9 to death.
Old Nov 6, 2010 | 10:32 PM
Hahns5.2's Avatar
Hahns5.2
I doubt gas mileage is any worse at 2800RPMs compared to lugging the engine at 2000RPMs and killing your tranny to boot.
Old Nov 7, 2010 | 09:44 AM
PurplDodge's Avatar
PurplDodge
You'll do fine.
