Need some opinions
Old 11-07-2010 | 12:21 AM
Yellow99's Avatar
Yellow99
so in my searches i couldnt find gear to gear timing, so i shall assume they dont have one?
Old 11-07-2010 | 01:28 AM
UnregisteredUser's Avatar
UnregisteredUser
Ignition timing is always decided by the PCM. The MSD boxes throw the first spark right where the PCM wants it, then add the additional sparks (below 3000 RPM) immediately afterward.
Old 11-07-2010 | 11:18 AM
Yellow99's Avatar
Yellow99
I was going to change out the timing chain does anyone make a gear to gear that works? i only find it for older sb
Old 11-07-2010 | 12:50 PM
UnregisteredUser
I've searched high and low for a gear drive for one of these beasties but failed to find one. I don't particularly like the whine of a gear drive, but I would gladly accept it as the price for bulletproof durability... if there were one available.
If it should happen that you find one in a place I haven't looked, please let me know about it.
Old 11-07-2010 | 01:24 PM
merc225hp's Avatar
merc225hp
I found this at milodon, It might be for a la series block, I am not sure but I think it should work. Maybe someone can tell if LA and Magnum timing sets will inter change.
http://www.milodon.com/gear-drives/g...d-sb-chrys.asp
Old 11-10-2010 | 08:32 PM
Yellow99's Avatar
Yellow99
What TB should I get and should I get intake bored to match?
Quick Reply: Need some opinions
