P1762&1763
Old Nov 6, 2010 | 04:13 PM
wyomingdodge7's Avatar
wyomingdodge7
Default P1762&1763
About 1000 miles ago I replaced the governor sensor and the solenoid after a P1756 code. Ran fine for those thousand miles then I just got back from a 400 mile trip and about 3 miles from home my CEL comes on. I stop at home and get a P1763 code and a P1762.
1762 The Governor Pressure Sensor input was too high or too low for 3 consecutive park/neutral calibrations.
1763 The Governor Pressure Sensor input is too high
What would have caused this and how can I fix it?
Old Nov 6, 2010 | 05:00 PM
Pressure sensor and solenoids are know trouble makers in these transmissions. Replace 'em both. Just get a filter kit for your trans, (46RE), six or so quarts of ATF +4, and the solenoid and sensor. You can grab the 01 service manual from the FAQ section here, and it will show you where they are, and how to replace them.
Old Nov 6, 2010 | 06:03 PM
wyomingdodge7
I just changed those 1,000 miles ago.
Old Nov 6, 2010 | 06:27 PM
drewactual's Avatar
drewactual
Did you change your filter too? Did you refill with AT+4? Both are important. Your filter may be clogged up or there may be debris in your pan creating pressure issues. Are the parts you got Mopar or aftermarket? I've heard of 'rebuilt' solenoids causing issues too- a lot of aftermarket items like these are rebuilt, or rejected Mopar parts.
I recall you having this issue about two months ago. Sucks that its back huh? Good luck dude.
Old Nov 6, 2010 | 06:44 PM
wyomingdodge7
Ya i used all Mopar parts and everything. What is my best option?
Old Nov 6, 2010 | 06:54 PM
drewactual's Avatar
drewactual
I don't know dude. Other than these butt **** simple things I'm lost when it comes to trannies. Maybe somebody else will contribute with something that can help us both out. You could also skim through Monte's tranny thread for info as well.
Wish I could help ya more but it sounds like its over my head at this point.
Old Nov 7, 2010 | 12:05 AM
Drop the pan, pull the parts, see what they look like. Are they clogged with sludge? Clean 'em out, and you will be good to go.
CAREFULLY look over the wiring harness in there, any rubbed thru wires? Broken? might check continuity of the circuits while you have the pan off.
Check the external connectors as well. Are they still reasonably well sealed? Contacts clean? Not all corroded?
Check the pins at the PCM as well. There is a factory service manual available for download in the FAQ section here. Grab it, from there, you can see which connector/pins you are concerned with.
Old Aug 20, 2011 | 02:50 PM
wheelz's Avatar
wheelz
Hi I have read you guys saying to go to the FAQ section and get the service manual but for the life of me I can not find it can you provide a link?
2001 1500
Old Aug 20, 2011 | 02:51 PM
zman17's Avatar
zman17
Retired Moderator - RIP
It's right on the first page dude.
Old Aug 20, 2011 | 03:46 PM
wheelz's Avatar
wheelz
I looked and looked and I can not find it.
Thanks for trying.
