Lift spring idea
Old Nov 8, 2010 | 11:26 AM
willstruck's Avatar
willstruck
Default Lift spring idea
I want to lift the front of my diesel up 3". My springs are pretty saggy, though, so I want to replace the springs, not just use spacers. I can't find 3" lift springs for a diesel, though. Top Gunz has 3.5", which might work, but I don't want to have to replace the control arms or other stuff at this point. I was thinking, though, what about using 5" lift coils for a gas truck? Wouldn't it work out to 3" of lift, plus a nicer ride since the spring rate isn't as stiff?
Also, has anyone built leaf packs for these trucks? I want to lift the rear about 2", and wouldn't mind doing it with a new pack rather than AALs, but I need to know what pack to modify, and what leafs to add into it to get the lift and spring rate needed for these trucks.
Old Nov 8, 2010 | 11:55 AM
97ramnj's Avatar
97ramnj
You think your springs sag now? Throw the gas ones under the weight of That cummins and see what happens. On top of the fact it'll ride like garbage. Keep searching for springs or just put in a two inch leveling kit. Don't use gas springs on that diesel
Old Nov 8, 2010 | 12:10 PM
zman17's Avatar
zman17
Retired Moderator - RIP
+1... Replace the front springs with new and get some 2 1/2 or 3 " spacers. Anything over 3" and you need a whole lot of other mods to the suspension components.
Old Nov 8, 2010 | 05:12 PM
97ramnj's Avatar
97ramnj
id stick with a 2 inch on top of new diesel springs. youll be happier then you are now
Old Nov 8, 2010 | 05:19 PM
willstruck's Avatar
willstruck
Alright, thanks. It was an idea, but I figured not a good one. Anyone know how much replacement stock springs run?
Old Nov 8, 2010 | 05:22 PM
dodgeman52's Avatar
dodgeman52
lmctruck.com there like a 100 a peice or maybe try rockauto.com
Old Nov 8, 2010 | 05:23 PM
dodgeman52's Avatar
dodgeman52
http://www.rockauto.com/catalog/x,ca...,parttype,7512
Old Nov 8, 2010 | 06:32 PM
97ramnj's Avatar
97ramnj
try checking like skyjacker, you might be able to get a set for like 200 bucks with a lil lift. maybe 2 inch lift springs. not sure whats out there but i know there around 200
Old Nov 9, 2010 | 12:42 PM
willstruck's Avatar
willstruck
Hmm. I bet on those 3.5" lift coils, there is a dead coil when the truck sits. It would be safe to trim it, and easily lower the truck that half inch...
