Engine Trouble
Old Nov 8, 2010 | 04:50 PM
Thumpper369's Avatar
Thumpper369
Default Engine Trouble
i have 2001 dodge ram 5.2L 4x4 sport edition, when i start it wants to rev up and then down it will go up to almost 1000 then down to 500 then after like 5 mins of running it stops, i put a new set of plugs in because before it would run really rough at start but then be fine had ****ty plugs in it bought wrong kind. after new plugs it ran fine for like a week maybe less then i was driving and it like bogged down and almost died, it did that alot barely made it home it sounded like not enough gas or to much gas. i kinda noticed a day or so before it started doing this i would push my foot on the accel it would lag then all of a sudden kick in. so does anyone have any ideals?
Old Nov 9, 2010 | 06:02 PM
Thumpper369
Oh yeah forgot to add when i changed the spark plugs, the spark plug in the cylinder closest to the fire wall on the passenger side was kinda brown and seemed to be a lil wet
Old Nov 9, 2010 | 06:07 PM
Gerehead8's Avatar
Gerehead8
Probably a sensor. Maybe the IAC (idle air control). You should clean your TB (throttle Body).
Might need plug wires and a cap and rotor.
Old Nov 9, 2010 | 06:24 PM
Thumpper369
yea after reading more and more threads and stuff on here think imma start with the TPS and IAC first then maybe plenum aslong as i have had the truck it has always kinda ran like **** at first startup then after few mins runs okay
Old Nov 9, 2010 | 06:28 PM
dhvaughan's Avatar
dhvaughan
well - i recently responded to a poster that had this problem, and based on my own experience - I felt positive that it was a bad TPS. so he replaced his tps for $40-50 and it didn't help it one bit. with that disclaimer - i've had surging idle twice, surging from 1000-1500 up, down, up, down, up down. both times it was a bad tps. $40-50 at any parts store.
if you do replace yours, and its not the problem, keep your old one as a spare. its worth its weight in gold for blind swaps like this.
