What Causes This?
Old Nov 11, 2010 | 10:39 PM
DodgeRam10's Avatar
DodgeRam10
Originally Posted by a-hall
DO NOT GO WITH BOSCH!!! Go to summit racing or jegs and order the NTK o2 sensors. Thats what i think is wrong with my truck right now damn bosch o2sensors
ok sounds good ill check out the ntk
Old Nov 12, 2010 | 04:11 AM
UnregisteredUser's Avatar
UnregisteredUser
If yours is not a federal emissions truck, you've got only two sensors. Crawl underneath and look.
Go with NTK (NGK), period.
Myself, when one sensor goes bad all of them get replaced. It's cheaper to just replace one, but it's less headache over time to shotgun the whole lot. Unless the difference is leaving your kids hungry or without Christmas, do them all at once and be done with them for another 100,000 miles or so.
Old Nov 12, 2010 | 05:03 AM
Sixtysixdeuce's Avatar
Sixtysixdeuce
Originally Posted by dhvaughan
4 o2's will be expensive.
P0420 is bank 1, which is drivers side.
i'd probably start with just the drivers side, post-cat (rear). why waste money.
Yes, P0420 OBD II universal definition is bank one. However, there is only one cat monitor on his truck.
To the OP-
Most likely it is a failed cat, as there are a host of other P-codes to indicate sensor-related problems (P0136-P0141). If you want to be sure, just back probe the signal wire on the cat monitor (downstream O2), and watch the voltage. It should hover around 300 mV and shouldn't fluctuate more than about 50 mV up or down. If it's switching like an upstram would, the cat is junk.
The guy at magnaflow is half right. While most of the time a cat failure is just a cat failure, often times on these rams, the oil from the plenum leak gums up the works in that honeycomb, and they stop burning the excess hydrocarbons.
Old Nov 12, 2010 | 07:09 AM
dhvaughan's Avatar
dhvaughan
Originally Posted by DodgeRam10
also i think i have four sensors so should i replace them all?
he says he has 4 sensors - which would be true on a california emissions. since he lives in arizona, its possible that he's got that setup.
if you do have a 4 sensor system, bank 1 is drivers side. if you have a 2 sensor system, the only pair is named bank 1, but its located on the passenger side.
Old Nov 12, 2010 | 09:09 AM
Sixtysixdeuce
I somehow missed that. Ooops. But.....
Don't the California models use a four sensor system with two monitors for the single cat? I'm pretty sure they have one that installs in the cat itself, and then a true downstream. I could be mistaken, but I believe that on-the-cat sensor and an air injection system are the only differences for a California model exhaust; still a two-into-one cat set-up.
Old Nov 12, 2010 | 09:48 AM
The Cali versions have two 'pre-cats' with O2 sensors on both sides. Then, a third, unmonitored cat further downstream. (this might vary by model year..... not sure on that.)
Old Nov 12, 2010 | 10:02 AM
Sixtysixdeuce
OK, I'll have to go with that, since I don't really remember. We don't see that many cali trucks here in Denver, and it's likely that the example I'm remembering could have been a pre-OBD-II or one that had an expensive cali system replaced with a cheaper Federal compliant one after failure outside of California. I don't believe I've ever seen a 2nd gen with pre-cats.
Old Nov 12, 2010 | 10:04 AM
They don't make it to Michigan real often either.
Old Nov 12, 2010 | 06:20 PM
sprntpshr's Avatar
sprntpshr
Or if it was up here, a Cali truck would be sleeping in the shop now for the winter....
sprntpshr
Old Nov 12, 2010 | 08:29 PM
DodgeRam10's Avatar
DodgeRam10
i crawled under and looked and i doonly have two sensors, i also erased the code and drove it for a while and it hasnt come back on, so when i get some money together im going to replace both sensors, and when i get even more money i might get the magnaflow direct fit cat for i found for $165( found a coupon... its normally $206...thought that was a pretty good deal.
