Quick alternator question:
Old Nov 12, 2010 | 12:18 PM
VOATMJ1's Avatar
VOATMJ1
Default Quick alternator question:
Recently the lights on my truck are flickering slightly, and really visible when the dome lights are on. Now even the dash lights are doing it, and when I rev the engine it kind of goes away. The volt meter on the dash says the alternator it is charging at 14.5 volts, and when I put a multimeter on the battery posts with the engine running it says 14.55 to 14.6 volts. Once, the dash volt meter went off the chart past the 18 volt mark and caused the chime to sound and a check gage light to come on. I stopped the truck and then restarted it, and the volts went back to normal. This has happened twice. Is this a sign of a failing alternator? Winter is approaching fast, and I need a reliable alternator. Thanks!
Old Nov 12, 2010 | 01:02 PM
J415's Avatar
J415
Take it to ORielys to get tested.
Old Nov 12, 2010 | 05:35 PM
Isn't the regulator in the PCM? (which, in this case, would be more likely to be the failing part??)
Old Nov 12, 2010 | 07:00 PM
J415's Avatar
J415
^Yup, it sure is!
Old Nov 12, 2010 | 07:28 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Have the battery checked too. What does the voltmeter read on the battery when the truck is off?
Old Nov 16, 2010 | 02:37 PM
VOATMJ1's Avatar
VOATMJ1
Brand new battery this summer.
Old Nov 16, 2010 | 04:50 PM
zman17's Avatar
zman17
It could be defective, and it won't hurt to have it checked.
