Slipping belts... not!
Old Nov 13, 2010 | 11:08 AM
zman17's Avatar
zman17
Retired Moderator - RIP
e-fan = electric fan
Originally Posted by lvolson
Thank you all for the advice. After looking through the manual forever last night, I did find a short blurb about bearings that could go in the waterpump that would cause that noise. There was some mention about the fan clutch also.
I guess I'll do the "jiggle" test on everything.
Drew, thanks for the mod list. The SCT will probably be my first mod after I fix anything broken and/or breaking. I am not sure what an "e-fan" is but I'll look it up.
Old Nov 14, 2010 | 02:57 PM
lvolson's Avatar
lvolson
I consider the plenum a "repair" so I will most likely wait on the SCT until that is done.
About the E fan... I assume there is a thread on it somewhere but since I have you here... what belt would I use (I assume a shorter one)?
Old Nov 14, 2010 | 03:05 PM
drewactual's Avatar
drewactual
nah, same belt.. pulley stays on there, it's just the clutch fan isn't attached anymore.. I actually have my old clutch fan in my truck box, on the 'count I was a little suspicious of the e-fan for a while... I figured if the e-fan failed, I could put the clutch fan back on right there on the side of the road..
I've had the e-fan on for a month and a half or so now, and I'm very pleased with it.
Old Nov 14, 2010 | 03:06 PM
E-fan just eliminates the fan. Doesn't change belt routing, or belt length. Still gotta turn the water pump.
Just relieves the engine of the strain of having to turn that fan all the time. Good for a few horsepower, and a more efficient cooling system.
Old Nov 14, 2010 | 03:47 PM
slider15004x4's Avatar
slider15004x4
Originally Posted by 95RAM360
and as for the 4.56's....just get a D60 front, and D607/70 rear with 4.10's....can do it with http://car-part.com for about $1,000 and those axles are WWWAAAAAYYYYY better then what you have now.....thats the way im going when im ready.
What would I search for to find the correct axles for my truck. I searched under 1996 1500 and only could get up to 3:90 and the price was like $1400 for just one axle. If I search for 2500 I can find the axles, but from what I understand that takes a bunch of modifications to use them. Thanks in advances for any help you can give me.
Old Nov 14, 2010 | 04:00 PM
zman17's Avatar
zman17
You are looking for a DANA 44 front axle and a 9.25 Dodge rear. Good luck finding 4:10's from a JY. Not gonna happen.
EDIT, and you are right, there are mods that need to be done to swap in a D60. Forget it.
Old Nov 14, 2010 | 07:34 PM
lvolson's Avatar
lvolson
I got tied up today so I never got to my water pump. For hahas I tried the WD40 test. After spraying a LOT of WD40 on the belt, the squealing stopped for about 5 seconds before slowly coming back.
Oh well. I want to play with it anyway.
EDIT: By the way, when I was shopping for waterpumps, I found the Edelbrock Victor Series Water pumps. They are about twice the cost of the one I bought. After reading about the e-fans, Tuners maing engines run hot, etc., I started thinking a "high performance" waterpump seems like a good investment... again, assuming my problem is the waterpump.
Old Nov 14, 2010 | 10:37 PM
I am not really sure how I feel about "high performance" water pumps..... its a pump. it moves water. but, only when the thermostat lets it. Does the velocity of water moving past the thermo make a difference? I really can't see it..... It might make the heater work better..... Now, if it was a higher quality build, with better seals/bearings/whathaveyou, that lasted twice as long as the pump for half the price, I could almost justify the additional cost. Almost.
Old Nov 15, 2010 | 07:05 AM
lvolson's Avatar
lvolson
Here is what they CLAIM to do. How much different it is from any other waterpump, who knows? They claim only 1% difference between the sides... if a regular pump has 2%, I suppose you don't gain much. I guess I'll have to look into the regualr pumps.
Of course, this is why I never get anything done... I always have to optimize.
Old Nov 16, 2010 | 09:56 AM
lvolson's Avatar
lvolson
We now have.... wait for it...
SILENCE OF THE RAM!
(sorry, had to do it!)
I took the belt off last night and did the wiggle test on everything. Decided since the waterpump was not loose and showed no signs of leaks that it was ok.
The tensioner was older than dirt and pretty weak (I am pretty sure it was the original.). For hahas, I replaced the idler pulley and drive belt at the same time. Though I can't say for certain which part fixed the squeal, because the belt and idler were almost new, my money is on the tensioner!
