A couple questions...
Old Nov 15, 2010 | 06:57 PM
a-master's Avatar
a-master
Default A couple questions...
Wanna do my gears... And hopefully a locker. I found a nice 4.88 kit (I think its nice) and I want your guys opinion. Recommendations on a locker? What else do I need exactly? As in:
-Front gears
-Rear gears
http://cgi.ebay.com/ebaymotors/CHRYS...ht_4531wt_1165
And it seems that my truck's ABS does not work because my front tires will lock up in the rain. But my rear ABS sensor is out (brake light/ABS light at same time), so I know the truck is equipped with it. odd...
Old Nov 15, 2010 | 08:43 PM
For each axle:
Gears. (ya, no kidding?? )
Master Install Kits. (bearings, shims and such)
Seals. (you have it apart, might just as well.)
Whatever other bearings you care to replace. (axle bearings? only applies to rear, fronts are hub/bearing assembly, if they are still good, put 'em back on.)
Fluid. If you get a clutch style limited slip, make sure it either has the additive, or, get some of that too.
Someone else can chime in on lockers.
Old Nov 16, 2010 | 08:48 AM
a-master's Avatar
a-master
Thanks, any other responses?
