replaced trans , drives.. wont shift? help? :)
Old Nov 17, 2010 | 06:10 PM
bjarki's Avatar
bjarki
Default replaced trans , drives.. wont shift? help? :)
hey i just replaced my 46RE trans ,
now i can feel it shifting into 2 gear , also while in D it seems like it revs a little too much sometimes to get going , but it will not go into third or higer .
my transfer case is from a 99 durango , it says 242 on it , and the sensor on the TC is not connected, it has a different plug than the wiring in the car ,
my speedo does not work either at any speed.
are these symptoms related?
also when i shift into reverse i hear a slight whine coming from the trans , normal?
thanks in advance
Old Nov 17, 2010 | 06:45 PM
zman17's Avatar
zman17
Retired Moderator - RIP
The tranny might have issues, but I'm not touching this with a ten foot pole. Your Ram should have a 231 TC in it, simple as that.
Old Nov 21, 2010 | 07:06 AM
bjarki's Avatar
bjarki
update , i swapped the governor sensor and it does everything normally now...
i know the truck should have a 231 TC but parts for these cars are extremely rare here in Iceland so we use whatever we get our hands on to keep'em running...
now i need to figure out if a stock 95 VSS will work with my 242 TC
Old Nov 21, 2010 | 07:11 AM
zman17's Avatar
zman17
There is a thread going on right now with a guy doing this swap. https://dodgeforum.com/forum/2nd-gen...in-98-ram.html
Old Nov 21, 2010 | 07:31 AM
bjarki's Avatar
bjarki
thanks man
