if the sound is coming from the front axle area, then its got to be either brakes, u-joints, wheel bearing, cad axle disconnect, or differential.
put it up on jack stands.
The u-joints, CAD unit, wheel bearings and brakes are all new so I'm thinking Dif. It is definatly coming from the front so I can't see it being the rear output. The driveshafts have almost 0 play up,down, side to side. But the rear shaft has some play when I spin it. About an inch or so. My big jack stands are in Illinois so I have to wait till I get them back to see. Thanks for the input guys
