Grinding at full turn and brake.
I've noticed that when I turn the wheels to the stops and reverse while using the brake to back out of the drive I can hear a metal on metal grinding noise coming from the front, and it is LOUD! My thoughts are that I have a 95 but my wheels are from a 96. I am pretty sure they have the some backspacing and specs but that is the only thing that I can think of. Any Ideas out there or someone who has had this problem that could tell me how they fixed it... Thanks!
you'll get a power steering whining noise when you hit the stops.
otherwise, put it up on jack stands, crank it up and turn the wheels and spin the tires and see if you can duplicate the noise.
be a little careful about turning the wheels without the engine and ps running. i pushed mine back and forth the other day while not running and it spit ps fluid out the top of the reservoir. it had never done that before.
No it's definatly not power steering whine. It does that all the time. It almost sounds like the caliper rubbing on the wheel. It's a scary loud grinding noise but it will only do it if I turn the wheel all the way to the right and reverse and use the brake to slow coming out of the drive at slow speeds. Maybe a camber issue?
jeez...thats what my truck started doing, then it got worse and it was my transfer case chewing up its internals due to the snap ring failure....
Trending Topics
I just got the chills 95RAM360.... I just put this tcase in about 20k ago. I did see a Ram come into the shop and made a sharp turn out of the door and I heard it. I stopped him and he said it's always done that and he has 285/75's. Wheel spacers? If it's the t-case could I remove the front shaft to stop it?
Transfer Case Saver time.
