Back Up Light Fuse BLOWN!!!????
Old Nov 22, 2010 | 12:14 AM
kuziwr's Avatar
kuziwr
Default Back Up Light Fuse BLOWN!!!????
Every time i put my 97 Ram into reverse the fuse blows! Has anyone had this problem before. The motor and trans are not original, bulbs are good, but it does have a factory tow package with a hitch.
Any ideas, or where do i start looking?
Old Nov 22, 2010 | 12:16 AM
Disconnect the trailer harness, see if that doesn't fix it.
Old Nov 22, 2010 | 03:59 AM
rczanstke's Avatar
rczanstke
Is the wiring stock? Something is drawing more power than the fuse can handle. A short maybe? What else besides the reverse lights are connected to that fuse? The only thing I could suggest is to follow the wires and check for any problems.
Old Nov 22, 2010 | 07:00 AM
dhvaughan's Avatar
dhvaughan
trailer wiring.
the 7 way trailer connector has a pin for the backup lights. center one maybe? your backup light is shorted to ground somewhere in the harness or the connector.
even if you don't have the 7 way, the previous owner may have done something creative. my previous owner put the reverse lights on the ground pin of the 4 way...
Old Nov 22, 2010 | 09:40 PM
holmesd789's Avatar
holmesd789
I'll third the trailer wiring. Untill I replaced the plug on my truck and trailer with a new one, my reverse light fuse would blow every time I backed up with my trailer on.
