code p305 after getting gas?
Old Nov 22, 2010 | 01:13 PM
97r/tram's Avatar
97r/tram
Default code p305 after getting gas?
I've noticed a pattern with my truck throwing the cly 5 misfire code to after I get gas. The truck starts missing like crazy and pours white smoke and the on comes the cel. After a few days it'll go away until I need gas again and after it'll repeat the process. Any ideas?
Old Nov 22, 2010 | 01:17 PM
Get the water out of your gas tank? Try getting gas somewhere else? Are you losing any coolant by chance?
Old Nov 22, 2010 | 01:25 PM
dodgeboy1979's Avatar
dodgeboy1979
when was the last time you did a tune up? (plugs, wires, cap rotor). Try switching the plug wire and plug out and see if that fixes it.
97r/tram's Avatar
97r/tram
It eats a little coolant
Old Nov 22, 2010 | 02:02 PM
Try running some gas dryer thru it, and see if that improves anything.
Old Nov 22, 2010 | 02:07 PM
97r/tram's Avatar
97r/tram
THanks man. I just did head gaskets and worked the heads. They're fine and I have new NGK v power plugs, wires and a new cap. However I've got an accel cap. Are those junk?
